Set Balance Variables (Territory Design Tools)
汇总
Configures variables to be used in the balancing process.
用法
  • The variables will be used according to relative weight, which is calculated based on a specified preference for each variable.
  • Preference refers to the relative weight of each variable.
  • Preferences from all of the variables must total 100 percent.
  • Set the Balance Variables parameter weight value to zero if you want to disable the variable when balancing.
参数
标注 说明 数据类型
Input Territory Solution
The name of the input territory solution.
Group Layer; Feature Dataset; String
Level
The name of the level to which the calculated field will be added.
String
Balance Variables
The variables that will be used in the balance process.
值表列:
  • Variable—The defined input.
  • Weight—The amount of influence a given variable has in the analysis.
Value Table
派生输出
标注 说明 数据类型
Updated Territory Solution
The updated territory solution.
Group Layer
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: Requires Business Analyst
  • 标准: Requires Business Analyst
  • 高级: Requires Business Analyst
