Validate Territories (Territory Design Tools)
汇总
Validates a territory solution for invalid territories.
用法
Run this tool after manually editing the territory solution. Any violations will need to be reviewed and resolved manually.
Validation issues will be included in the tool messages and added to the
Territory Validation Errorsfield orFeature Validation Errorsfield.Territory validation issues will be displayed in the
Territory Validation Errorsfield.The
Feature Validation Errorsfield will display features that contain validation issues for a territory.The tool will analyze the territory solution for the following errors:
Barriers violation
Buffer distance constraint violation
Minimum attribute constraint limit violation
Maximum attribute constraint limit violation
Minimum distance between centers constraint violation
Maximum territory radius constraint violation
Territory is empty
Territory center is undefined
Territory is not contiguous
Territory has holes
Territory name is not unique
参数
| 标注 | 说明 | 数据类型 |
Input Territory Solution |
The territory solution that will be validated. |
Group Layer; Feature Dataset; String |
Level |
The level that will be analyzed in the validation. |
String |
派生输出
| 标注 | 说明 | 数据类型 |
Updated Territory Solution |
The territory solution output. |
Group Layer |
环境
此工具不使用任何地理处理环境。
许可信息
- 基本: Requires Business Analyst
- 标准: Requires Business Analyst
- 高级: Requires Business Analyst
