Apply Feature Level Metadata (Topographic Production Tools)
汇总
Applies values from a metadata record in the FeatureLevelMetadata table to selected features that have matching attribute fields.
用法
The Metadata Favorite parameter value is a record in the FeatureLevelMetadata table. The tool will apply a record's associated values to corresponding attributes for the specified features in the Input Features parameter.
The FeatureLevelMetadata table is included with the ArcGIS Topographic Mapping product data files.
The field types in the FeatureLevelMetadata table must match the field types in the feature layers being updated. If they don't, the tool will fail with an error message indicating that the field types must match before processing.
参数
| 标注 | 说明 | 数据类型 |
Input Features |
The inputs to which the Metadata Favorite parameter value will be applied. |
Feature Layer |
Input Metadata Table |
The path to the metadata table containing the records that will be used to populate attributes. |
Table View |
Metadata Favorite |
The record that will be used to populate attributes. The available options depend on the records available in the metadata table. |
String |
派生输出
| 标注 | 说明 | 数据类型 |
Updated Features |
The Input Features layer with updated attributes. |
Feature Layer; Feature Class |
环境
此工具不使用任何地理处理环境。
许可信息
- 基本: No
- 标准: Requires Topographic Mapping
- 高级: Requires Topographic Mapping
