Apply Masks From Rules (Topographic Production Tools)
汇总
Applies symbol layer masking to feature layers in a map based on an XML rule file and mask features created by the Make Mask From Rules tool.
注:
A product file installer is available for ArcGIS Topographic Mapping. The product files contain predefined XML masking rule files that can be used for cartographic production.
Learn more about product files
用法
  • The Make Mask From Rules tool must be run before this tool to create the mask feature classes stored in the mask feature dataset. The mask features created by the Make Mask From Rules tool are used to define the extent of the masks applied to the layers in the map.
  • The color rules are defined in an XML file. A rule specifies that symbolized features of a particular color be masked by a source feature that has a particular color.
    The following example rule is based on a map specification that dictates that a mask will be created for any location where the outline of a black symbol (color of 0,0,0,100 CMYK) intersects a piece of black annotation.
    <RuleGroup>
            <!-- CMYK Feature Masks -->
            <Mask Size=".1" Units="Points" Type="Box"/>
            <Source SymbolPart="Text_Only" LayerType="AnnotationLayer"/>
            <Target SymbolPart="Outline_Only" LayerType="FeatureLayer"/>
            <TargetExclusions></TargetExclusions>
            <Rules>
                <Rule Name="FeatureMasks_Black_CMYK_1pt">
                    <MaskFeatureClass>FeatureMasks_Black_CMYK_1pt</MaskFeatureClass>
                    <Source Color="0,0,0,100"/>
                    <Targets>
                        <Target Color="0,0,0,100"/>
                    </Targets>
                </Rule>
            </Rules>
    </RuleGroup>
    注:
    Sample XML masking files are delivered in the Defense Mapping and Topographic Mapping product file installs. Use these sample XML files as a template to create custom masking rules.
  • The XML rule file is used to determine the symbol layers (such as fill, outline, and so on) that require masking based on the color of the symbol layer.
  • Any masks currently applied to the layers in the map will be removed when this tool is run. The resulting map will only have masks applied to layers that meet the results defined in the mask XML.
  • Set the coordinate system of the map to match the projection of the final printable map or other output product before applying masks. The coordinate system of the map should also match the coordinate system of the mask feature dataset.
    注:
    If the mask feature dataset is not projected to the proper coordinate system, the masks will not align with the features in the final printable map. Set the proper coordinate system on the masks feature dataset before running the Make Masks From Rules tool to avoid mask projection issues.
参数
标注 说明 数据类型
Input Map
The input map containing symbolized features such as a map in a project or a MAPX file on disk.
Map
Rule File
The XML file containing rules to define how features should be masked based on colors and symbol parts.
File
Mask Feature Dataset
The feature dataset containing the masking polygon feature classes created by the Make Mask From Rules tool.
Feature Dataset
派生输出
标注 说明 数据类型
Updated Map
Output map with updated masks.
Map
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
  • 高级: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
