Download Job Files (Topographic Production Tools)
汇总
Downloads and extracts the latest version of the job files from a topographic production server for manual operations.
注意:
This tool is intended for use with Topographic Production workflows and is designed to be run as a step in an ArcGIS Workflow Manager workflow. Workflow Manager must be properly configured to use this tool.
用法
The active portal in ArcGIS Pro must be the portal that hosts the ArcGIS Workflow Manager service and Topographic Production service items. You must sign in to ArcGIS Pro with the account that has access to both services.
Accounts with administrator access can download files for any job item, and accounts without administrator access can only download the files for their own job items.
注:
The account assigned to the ArcGIS Workflow Manager Server job must be the account that created the job running on the Topographic Production service.
The topographic mapping job item must be paused on the server for this tool to run.
Job files are uploaded to the location specified in the
local_job_folderextended property of the Workflow Manager job. Accounts with administrator access can update this property's value.
参数
| 标注 | 说明 | 数据类型 |
Service Item |
The unique name or identifier of the Workflow Manager service item on the portal with topographic production capabilities. Available Workflow Manager item options depend on the active portal in ArcGIS Pro. |
String |
Job Identifier |
The unique name or identifier of the currently active topographic product job. Available job item options depend on the Service Item parameter value. |
String |
派生输出
| 标注 | 说明 | 数据类型 |
Output Job Location |
The output location where the job files will be downloaded and extracted on the local machine. |
Folder |
环境
此工具不使用任何地理处理环境。
许可信息
- 基本: No
- 标准: Requires Topographic Mapping
- 高级: Requires Topographic Mapping
