Export Topology (Topographic Production Tools)
汇总
Exports a topology from a geodatabase to an .xml file.
The .xml file contains a definition of a topology, including feature class names, topology ranks, topology rules, and cluster tolerance, and can be used by the Import Topology tool to recreate a topology in a new feature dataset.
用法
  • This tool supports all data models and can be used on any geodatabase topology.
参数
标注 说明 数据类型
Input Topology
An existing topology in a geodatabase. All feature classes that participate in this topology will be listed in the output .xml file.
Topology; Topology Layer
Topology XML Document Location
The folder in which the .xml file will be written.
Folder
Topology XML Document Name
The name of the topology .xml file that will be created by the tool.
String
派生输出
标注 说明 数据类型
Output Topology XML Document
Output topology XML file created by exporting topology rules.
File
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires Topographic Mapping
  • 高级: Requires Topographic Mapping
