Generate Elevation Bands From Features (Topographic Production Tools)
汇总
Generates band features that represent elevation levels on a map product. The tool can be run with set values from standardized product specifications or with custom-defined values.
插图
Generate Elevation Bands From Features tool illustration
Map imagery before and after elevation bands are generated using the Generate Elevation Bands From Features tool.
用法
  • The Area of Interest layer must have only one feature selected.
  • The Area of Interest parameter value should be rectangle or square geometry. The tool may create incorrect bands if geometry other than rectangle or square is used.
  • Use a Contour Features parameter value that has been collected using meters or feet.
  • The Output Feature Class parameter value will contain the following fields:
    • Low_Value
    • High_Value
    • TintBand
    If the feature class already exists, ensure that these fields do too.
  • ArcGIS Pro JOG, TPC, and ONC database product files have been updated with the appropriate fields. The BM datasets are JOG_BANDS_A, TPC_BANDS_A, and ONC_BANDS_A, respectively.
  • You can specify a Band Interval parameter value to create bands at regular intervals, such as every 500 meters, or you can specify irregular intervals, but not both. If a Band Interval parameter value is specified, the Band Values parameter will be inactive.
  • If a standard product such as JOG-A, TPC, or ONC is specified for the Product parameter, the standard ranges defined by the product specification will be automatically populated for the Band Values parameter. Bands can be added or removed as required.
  • If Custom is specified for the Product parameter, the Band Values parameter values must also be provided.
  • If a band interval is specified, the resulting band polygons will be created based on the interval, starting with 0. For example, if the input contours are in meters and the value for the Band Interval parameter is 500, the output bands will be created from 0 to 500 meters, then 500 to 1,000 meters, and so on.
  • If the band values specified do not fully cover the range of elevations in the selected Area of Interest (AOI), no bands will be created over those areas. For example, if Band 1 is defined as 500 to 750 meters and Band 2 is defined as 750 to 1250 meters, but the elevation range in the specified AOI is 300 to 1500 meters, no elevation bands will be created for contour-bounded areas less than 500 meters or greater than 1250 meters.
  • The specified Band Interval parameter value or the resulting interval from specifying Low and High values for the Band Values parameter, must be divisible by the contour interval to ensure that the Output Feature Class parameter value isn't missing bands.
  • The generated bands will cover the extent of both the Contour Features and Exclusion Features parameter values to avoid gaps. If the Exclusion Features parameter value is not specified, the extent of the contour lines will set the bounds of the generated bands.
  • Ensure that contours cover the entire AOI specified in the Area of Interest parameter. Open contour lines must extend up to or beyond the specified AOI.
  • Remove any intersecting contour lines from the Contour Features parameter value before running the tool; otherwise, the tool will report an error.
  • The contour lines specified for the Contour Features parameter should be continuous. Use the Merge Lines By Pseudo Node tool to merge line features with matching attribute values.
参数
标注 说明 数据类型
Contour Features
The polyline feature layer that contains the contours. The information for the output bands will be derived from these features.
Feature Layer
Elevation Field
The field in the Contour Features feature layer from which the elevation values will be derived.
Field
Area of Interest
The AOI for the area where the elevation bands will be created. The AOI is typically stored in an index feature class that contains the extents for standard map sheets. A single feature must be selected on the feature class that is specified.
Feature Layer
The feature class that will contain the banding features.
Feature Class
Exclusion Features
(可选)
The feature layers that define areas where bands will not be created.
Feature Layer
Product
(可选)
A supported map product, which determines the values for the Band Values parameter unless Custom is specified for this parameter. If left blank, at least one pair of Low and High values is required for the Band Values parameter.
  • JOG-A—The Joint Operations Graphic-Air product
  • ONC—The Operational Navigation Chart product
  • TPC—The Tactical Pilotage Chart product
  • Custom—A custom product
String
Band Interval
(可选)
The interval specified when the band interval type is regular. This parameter is only available when Custom is specified as the Product parameter value.
Long
Band Values
(可选)
The low and high values in the bands that will be created. These values will be populated automatically from an .xml file if a particular product is specified for the Product parameter value; however, these values must be provided manually if Custom is specified for the Product parameter value and at least one pair of Low and High values is required. If no product is specified, at least one pair of Low and High values is still required.
值表列:
  • Low—The lowest value in the band to be created.
  • High—The highest value in the band to be created.
Value Table
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: No
  • 高级: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
