Update Topographic Production Service Database (Topographic Production Tools)
汇总
Updates the database used by an instance of the Topographic Production Service.
用法
  • The database specified in the Input Geodatabase parameter must be an enterprise database that contains the tables required for the Topographic Production Service.
  • If the database specified in the Input Geodatabase parameter does not contain the tables required for the Topographic Production Service, the tool will create them at run time.
  • Ensure that the user account in the Input Geodatabase parameter value has privileges to create data so that any additional tables can be created. Once updated, the .sde file can be set back to a user account with only data editor privileges.
  • If the tables in the database specified in the Input Geodatabase parameter are out of date, the tool will update them to the latest schema version.
  • If the Create backup geodatabase parameter is checked, the Input Geodatabase parameter value will be backed up to a file geodatabase at the location specified before the schema is updated.
    注意:
    Only the tables that belong to the Topographic Production Service will be copied to the backup database. This is not a full database backup.
参数
标注 说明 数据类型
Input Geodatabase
The enterprise geodatabase that will be updated to the latest schema version and contain the tables required for the Topographic Production server-object extension (SOE).
Workspace
(可选)
Specifies whether a backup geodatabase will be created.
  • 选中—A backup geodatabase will be created.
  • 未选中—A backup geodatabase will not be created. This is the default.
Boolean
Output Backup Geodatabase
(可选)
The file path of the backup geodatabase. This parameter is active when the Create backup geodatabse parameter is checked.
Workspace
派生输出
标注 说明 数据类型
Updated Geodatabase
The updated Input Geodatabase parameter value.
Workspace
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires Topographic Mapping
  • 高级: Requires Topographic Mapping
