ContingentFieldValue
Zusammenfassung
The ContingentFieldValue object contains properties that describe the properties of the field used for a contingent value.
Diskussion
ContingentFieldValue objects cannot be created directly. ContingentFieldValue properties can be accessed through the values object that is returned by the arcpy.da.ListContingentValues function.
Eigenschaften
Name Erläuterung Datentyp
code
(Schreibgeschützt)
If the contingent value uses a coded value domain, this property returns the code that is used for the contingent value.
Long
name
(Schreibgeschützt)
The name of the field that participates in the field group.
String
range
(Schreibgeschützt)
If the contingent value uses a range domain, this property returns the minimum and maximum values of the range for the contingent value.
Long
type
(Schreibgeschützt)
Specifies the type of field value used for the contingent value.
  • ANY—The field value can be any value.
  • CODED_VALUE—The field value is a code used in a coded value domain that has been assigned to the field.
  • NULL—The field value is null.
  • RANGE—The field value is a subset range of a range domain that has been assigned to the field.
String
