ListContingentValues
Zusammenfassung
The ListContingentValues function lists the contingent values on a table. Search conditions can be specified for the field group name and subtype to limit the list that is returned.
Syntax
ListContingentValues(table, {field_group_name}, {subtype_code})
Parameter Erläuterung Datentyp
table
A table that has contingent values.
String
field_group_name
The field group name to limit the results returned. Only contingent values for the field group specified will be returned.
The default value is All.
String
subtype_code
The subtype code to limit the results returned. Only contingent values for the subtype specified will be returned.
Long
Rückgabewert
Datentyp Erläuterung
Object
A list of ContingentValue objects. Each object contains properties of the contingent value.
Codebeispiel
ListContingentValues example
List and describe the contingent value properties for a field group named MyFieldGroup.
import arcpy
CVs = arcpy.da.ListContingentValues("C:\\MyProject\\myConn.sde\\mygdb.USER1.myFC", "MyFieldGroup")
for cv in CVs:
    print("Subtype: {}\nIs retired: {}\nContingent Value Id: {}\nValues: \n".format(cv.subtype, cv.isRetired, cv.id))
    for v in cv.values:
        print(" Field Name: {}\n Field Value Type: {}""".format(v.name, v.type))
        if v.type == "CODED_VALUE":
            print(" Field Value Code: {}\n".format(v.code))
        if v.type == "RANGE":
            print(" Field Range: {}\n".format(v.range))
