ListDatabaseSequences
Zusammenfassung
The ListDatabaseSequences function lists the database sequences in a database.
This function is only supported for file geodatabases.
Syntax
ListDatabaseSequences(workspace)
Parameter Erläuterung Datentyp
workspace
A database that has one or more sequences.
String
Rückgabewert
Datentyp Erläuterung
Object
A list of DatabaseSequence objects. Each object contains properties of the database sequence.
Codebeispiel
ListDatabaseSequences example
List and describe the database sequences in a file geodatabase.
import arcpy
sequences = arcpy.da.ListDatabaseSequences("C:/Data/myGdb.gdb")
for seq in sequences:
    print('Sequence name: {}'.format(seq.name))
    print('Sequence start value: {}'.format(seq.startValue))
    print('Sequence increment value: {}'.format(seq.incrementValue))
    print('Sequence current value: {}'.format(seq.currentValue))
