SearchCursor
Zusammenfassung
The SearchCursor object establishes read-only access to the records of a feature class or table.
It returns an iterator of tuples. The order of values in the tuple matches the order of fields specified by the field_names argument.
Diskussion
Geometry object properties can be accessed by specifying the token SHAPE@ in the list of fields.
Search cursors can be iterated using a for loop. Search cursors also support with statements to reset iteration and aid in removal of locks. However, using a del statement to delete the object or wrapping the cursor in a function to have the cursor object go out of scope should be considered to guard against all locking cases.
The records returned by SearchCursor can be constrained to match attribute criteria or spatial criteria.
Accessing full geometry with SHAPE@ is an expensive operation. If only simple geometry information is required, such as the x,y coordinates of a point, use tokens such as SHAPE@XY, SHAPE@Z, and SHAPE@M for faster, more efficient access.
Syntax
SearchCursor(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {sql_clause}, {datum_transformation}, {spatial_filter}, {spatial_relationship}, {search_order})
| Name | Erläuterung | Datentyp |
in_table |
The feature class, layer, table, or table view. |
String |
field_names |
A list (or tuple) of field names. For a single field, you can use a string instead of a list of strings. Use an asterisk ( Additional information can be accessed using tokens (such as
String |
where_clause (Optional) |
An optional expression that limits the records returned. For more information on WHERE clauses and SQL statements, see SQL reference for query expressions used in ArcGIS. The default value is None. |
String |
spatial_reference (Optional) |
The spatial reference of the feature class. When this argument is specified, the feature will be projected (or transformed) from the input's spatial reference. If unspecified, the input feature classes' spatial reference will be used. Valid values for this argument are a If a spatial reference is specified, but the input feature class has an unknown spatial reference, neither a projection nor transformation can be completed. The geometry returned by the cursor will have coordinates matching the input, with a spatial reference updated to the one specified. The default value is None. |
SpatialReference |
explode_to_points (Optional) |
Deconstruct a feature into its individual points or vertices. If The default value is False. |
Boolean |
sql_clause (Optional) |
A pair of SQL prefix and postfix clauses organized in a list or tuple. An SQL prefix clause supports Use
Use
Use
An SQL prefix clause is positioned in the first position and will be inserted between the An SQL postfix clause is positioned in the second position and will be appended to the Hinweis:
The default value is (None, None.) |
tuple |
datum_transformation (Optional) |
When the cursor projects the features from one spatial reference to another, if the spatial references do not share the same datum, an appropriate datum transformation should be specified. The Learn more about datum transformations The default value is None. |
String |
spatial_filter (Optional) |
A geometry object used to spatially filter features. When this argument is specified, the cursor will limit the features returned, based on specified geometry and the spatial_relationship value. The default value is None. |
Geometry |
spatial_relationship (Optional) |
The spatial relationship between the input and the query geometry in the
The default value is INTERSECTS. |
String |
search_order (Optional) |
The order in which the spatial searches are applied by the RDBMS. This property only affects enterprise geodatabase data and is only applicable when specifying the
The default value is ATTRIBUTEFIRST. |
String |
Eigenschaften
fields (Schreibgeschützt) |
A tuple of field names used by the cursor. The tuple will include all fields and tokens specified by the The order of the field names on the If the |
tuple |
Methoden
reset()
The reset method resets the cursor back to the first row.
Codebeispiel
Use SearchCursor to step through a feature class and print specific field values and the x,y coordinates of the point.
import arcpy
fc = 'c:/data/base.gdb/well'
fields = ['WELL_ID', 'WELL_TYPE', 'SHAPE@XY']
# For each row, print the WELL_ID and WELL_TYPE fields, and
# the feature's x,y coordinates
with arcpy.da.SearchCursor(fc, fields) as cursor:
for row in cursor:
print(f'{row[0]}, {row[1]}, {row[2]}')
Use SearchCursor to return a set of unique field values.
import arcpy
field = 'Diameter'
# Use SearchCursor with list comprehension to return a
# unique set of values in the specified field
values = [row[0] for row in arcpy.da.SearchCursor(fc, field)]
unique_values = set(values)
print(unique_values)
Use SearchCursor to return attributes using tokens.
import arcpy
# For each row, print the Object ID field, and use the SHAPE@AREA
# token to access geometry properties
with arcpy.da.SearchCursor(fc, ['OID@', 'SHAPE@AREA']) as cursor:
for row in cursor:
print(f'Feature {row[0]} has an area of {row[1]}')
Use SearchCursor with a where clause to identify features that meet specific criteria.
import arcpy
fc = 'c:/base/data.gdb/roads'
class_field = 'Road Class'
name_field = 'Name'
# Create an expression with proper delimiters
delimited_field = arcpy.AddFieldDelimiters(fc, name_field)
expression = f'{delimited_field} = 2'
# Create a search cursor using an SQL expression
fc, [class_field, name_field], where_clause=expression
) as cursor:
for row in cursor:
# Print the name of the residential road
print(row[1])
Use SearchCursor and the Python sorted method to sort rows.
For additional sorting options, see the Python Sorting Mini-HOW TO.
import arcpy
fields = ['WELL_ID', 'WELL_TYPE']
# Use Python's sorted method to sort rows
for row in sorted(arcpy.da.SearchCursor(fc, fields)):
print(f'{row[0]}, {row[1]}')
Alternatively, sort using sql_clause if the data supports the SQL ORDER BY clause.
Hinweis:
The ORDER BY clause is only supported when working with databases. It is not supported by other data sources (such as dBASE).
import arcpy
# Use ORDER BY sql clause to sort field values
with arcpy.da.SearchCursor(fc, fields, sql_clause=(None, "ORDER BY WELL_ID, WELL_TYPE")) as cursor:
for row in cursor:
Use the SQL TOP clause to limit the number of records to return.
Hinweis:
The TOP clause is only supported by SQL Server databases.
import arcpy
# Use SQL TOP to sort field values
with arcpy.da.SearchCursor(fc, fields, sql_clause=('TOP 3', None)):
for row in cursor:
Use SearchCursor using a spatial filter with a geometry object.
import arcpy
arr = arcpy.Array(
[arcpy.Point(342917.4, 553980.8), arcpy.Point(366915.9, 594749.1)]
new_road = arcpy.Polyline(arr, spatial_reference=arcpy.SpatialReference(26971))
fc = r"C:\data\chicago.gdb\houses"
fields = ["ADDRESS", "OCCUPIED"]
fc, fields, where_clause="OCCUPIED != 'Vacant'", spatial_filter=new_road
) as cursor:
for row in cursor:
print(f'{row[0]}: {row[1]}')
Use SearchCursor using a spatial filter with a geometry object from another feature class.
import arcpy
fc = r"c:\connections\sqlserver.sde\DBO.ShipPositions"
fields = ["OBJECTID", "SHIP_NAME"]
searchPoly = [row[0] for row in arcpy.da.SearchCursor("searchArea", ["SHAPE@"])][0]
fc, fields, spatial_filter=searchPoly, search_order="SPATIALFIRST"
) as cursor:
for row in cursor:
