UpdateCursor
Zusammenfassung
The UpdateCursor object establishes read-write access to records returned from a feature class or table.
Returns an iterator of lists. The order of values in the list matches the order of fields specified by the field_names argument.
Diskussion
Update cursors can be iterated using a for loop. Update cursors also support with statements to reset iteration and aid in removal of locks.
Opening simultaneous insert or update operations on the same workspace using different cursors requires the start of an edit session.
The following includes some dataset types that can only be edited within an edit session:
Feature classes participating in a topology
Feature classes participating in a geometric network
Feature classes participating in a network dataset
Versioned datasets in enterprise geodatabases
Some object and feature classes with class extensions
In Python 2, UpdateCursor supports the iterator next method to retrieve the next row outside of a loop. In Python 3, the equivalent is performed by using the Python built-in next function.
Hinweis:
The Calculate Field and Calculate Fields tools can also be used to update field values.
Hinweis:
Using an UpdateCursor on a layer with a joined table is not supported.
Syntax
UpdateCursor(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {sql_clause}, {datum_transformation}, {explicit}, {spatial_filter}, {spatial_relationship}, {search_order})
| Name | Erläuterung | Datentyp |
in_table |
The feature class, layer, table, or table view. |
String |
field_names |
A list (or tuple) of field names. For a single field, you can use a string instead of a list of strings. Use an asterisk ( Raster fields are not supported. Additional information can be accessed using tokens (such as
String |
where_clause (Optional) |
An optional expression that limits the records returned. For more information on WHERE clauses and SQL statements, see SQL reference for query expressions used in ArcGIS. The default value is None. |
String |
spatial_reference (Optional) |
The spatial reference of the feature class. When this argument is specified, the feature will be projected (or transformed) from the input's spatial reference. If unspecified, the input feature classes' spatial reference will be used. Valid values for this argument are a The default value is None. |
SpatialReference |
explode_to_points (Optional) |
Deconstruct a feature into its individual points or vertices. If The default value is False. |
Boolean |
sql_clause (Optional) |
A pair of SQL prefix and postfix clauses organized in a list or tuple. An SQL prefix clause supports Use
Use
Use
An SQL prefix clause is positioned in the first position and will be inserted between the An SQL postfix clause is positioned in the second position and will be appended to the Hinweis:
The default value is (None, None.) |
tuple |
datum_transformation (Optional) |
When the cursor projects the features from one spatial reference to another, if the spatial references do not share the same datum, an appropriate datum transformation should be specified. An update cursor can perform a projection or transformation at two stages: when reading the features from the feature class on disk and when writing the updated features to the feature class. The |
String |
explicit (Optional) |
If a field has a default value and the field is nullable, using a value of Apply the explicit rule to all fields:
The explicit rule can also be applied to individual fields using a list of Boolean values. The list of values must be the same length as the list of fields. Apply the explicit rule to only the first two fields:
Boolean |
spatial_filter (Optional) |
A geometry object used to spatially filter features. When this argument is specified, the cursor will limit the features returned, based on specified geometry and the spatial_relationship value. The default value is None. |
Geometry |
spatial_relationship (Optional) |
The spatial relationship between the input and the query geometry in the
The default value is INTERSECTS. |
String |
search_order (Optional) |
The order in which the spatial searches are applied by the RDBMS. This property only affects enterprise geodatabase data and is only applicable when specifying the
The default value is ATTRIBUTEFIRST. |
String |
Eigenschaften
fields (Schreibgeschützt) |
A tuple of field names used by the cursor. The tuple will include all fields and tokens specified by the The order of the field names on the If the |
tuple |
Methoden
deleteRow()
Deletes the current row.
reset()
The reset method resets the cursor back to the first row.
updateRow(row)
Updates the current row in the table.
row |
A list or tuple of values. The order of values should be in the same order as the fields. When updating fields, if the incoming values match the type of field, the values will be cast as necessary. For example, a value of |
tuple |
Codebeispiel
Use UpdateCursor to update a field value by evaluating the values of other fields.
import arcpy
fc = 'c:/data/base.gdb/well'
fields = ['WELL_YIELD', 'WELL_CLASS']
# Create update cursor for feature class
with arcpy.da.UpdateCursor(fc, fields) as cursor:
# For each row, evaluate the WELL_YIELD value (index position
# of 0), and update WELL_CLASS (index position of 1)
for row in cursor:
if (row[0] >= 0 and row[0] <= 10):
row[1] = 1
elif (row[0] > 10 and row[0] <= 20):
row[1] = 2
elif (row[0] > 20 and row[0] <= 30):
row[1] = 3
elif (row[0] > 30):
row[1] = 4
# Update the cursor with the updated list
cursor.updateRow(row)
Use UpdateCursor to update a field of buffer distances for use with the Buffer function.
import arcpy
arcpy.env.workspace = 'c:/data/output.gdb'
fc = 'c:/data/base.gdb/roads'
fields = ['ROAD_TYPE', 'BUFFER_DISTANCE']
# Update the field used in Buffer so the distance is based on road
# type. Road type is either 1, 2, 3, or 4. Distance is in meters.
for row in cursor:
# Update the BUFFER_DISTANCE field to be 100 times the
# ROAD_TYPE field.
row[1] = row[0] * 100
# Buffer feature class using updated field values
arcpy.analysis.Buffer(fc, 'roads_buffer', 'BUFFER_DISTANCE')
Use UpdateCursor with a spatial filter to update field values.
import arcpy
arr = arcpy.Array(
[arcpy.Point(342917.4, 553980.8), arcpy.Point(366915.9, 594749.1)]
new_road = arcpy.Polyline(arr, spatial_reference=arcpy.SpatialReference(26971))
fc = r"C:\data\chicago.gdb\houses"
fields = ["OCCUPIED"]
fc, fields, where_clause="OCCUPIED != 'Vacant'", spatial_filter=new_road
) as cursor:
for row in cursor:
row[0] = 'Vacant'
