Export FAA 18B Shapefiles (Aviation Tools)
Zusammenfassung
Exports one or more FAA Advisory Circular 150/5300-18B compliant shapefiles from a geodatabase that contains the Esri Airports schema.
Verwendung
  • The input workspace must contain the Esri Airports data model.
  • Export shapefiles will contain the schema defined in Appendix D of AC 150/5300-18B.
  • Duplicate features are reported as warnings. More detailed information on which features are duplicates can be found in the Results window.
Parameter
Input Airport Geodatabase
The workspace that contains the airport data.
Workspace
Target Folder
The folder where the shapefiles will be written.
Folder
Input Feature Class
(Optional)
A list of feature classes that will be exported to shapefiles. If no value is provided, all feature classes in the input workspace will be exported to shapefiles.
String
Abgeleitete Ausgabe
Output Folder
The updated target folder.
Folder
Umgebungen
Current Workspace
Lizenzierungsinformationen
  • Basic: No
  • Standard: Requires Airports
  • Advanced: Requires Airports
