Export AIXM 5.1 Message (Aviation Tools)
Zusammenfassung
Exports aeronautical data to an Aeronautical Information Exchange Model (AIXM) 5.1 message.
An AIXM message is a standard data exchange format for aeronautical data. AIXM is a well-established information exchange format in the aviation domain. Using aeronautical data in this format is an important step in the creation of an Aviation Airports or Aviation Charting product. This tool allows you to export data from an Aeronautical Information System (AIS) schema or Esri Airports geodatabase as an AIXM message.
Verwendung
  • The Input Aviation Workspace parameter value must be a valid AIS schema or Esri Airports geodatabase workspace.
  • This tool exports data to an AIXM 5.1 message that is saved as an .xml file.
  • If you do not select a value for the Input Filter Layers parameter, the tool will run on all of the layers in the geodatabase. Once you apply a filter on one layer, you must apply a filter on all of the layers you want to export.
  • The export will honor definition queries set on the Input Filter Layers parameter value.
  • The following AIS entities can be used for the input feature layers: ADHP, ADHPCollocation, Airspace, ADHPSurfaceArea, ADHPSurfaceElement, ADHPSurfacePoint, ADHPSurfaceLine, ADHPThreshold, AirspaceAuth, ATSRoute, DesignatedPoint, EnrouteInformation, Frequency, GeoBorder, Marking, NavaidComponent, NavaidSystem, ObstacleArea, ObstacleStructure, OrgAuth, Service, SurfaceLightSys, and Unit.
  • Related AIS features will be included in the export message pursuant to mappings in the export configuration files. The export configuration files are 51ExportRelationships.json and 51ExportTemplate.xml and are under C:\Program Files\ArcGIS\Pro\Resources\Aviation.
  • The following Esri Airports entities can be used for input feature layers: AirfieldLight, AirportControlPoint, AirportSign, FrequencyArea, MarkingArea, NavaidEquipment, NavaidSite, Obstacle, ObstacleArea, Runway, RunwayEnd, and TaxiwayElement.
  • Related Esri Airports features will be included in the export message pursuant to mappings in the export configuration files. The following export configuration files are available under C:\Program Files\ArcGIS\Pro\Resources\Aviation:
    • AMDB_AIXM_ExportDomains.json
    • AMDB_AIXM_51ExportRelationships.json
    • AMDB_AIXM_51ExportTemplate.xml
  • If the Validate Output parameter is checked, you must be connected to the internet for the validation to complete.
  • If you validate the output AIXM 5.1 message, you can store it in the Output Validation Log parameter value.
Parameter
The AIS schema or Esri Airports geodatabase workspace.
Workspace
Output Message File
The exported AIXM 5.1 message as an .xml file.
File
Export Type
Specifies the AIXM temporality type the message represents.
  • Baseline—The message contains all features in a given message.
  • Snapshot—The message contains all features at a specific point in time.
  • Permanent Delta—The message contains updates in a given time slice in features as a result of a baseline update.
  • Temporary Delta—The message contains changes for some features in a given time slice representing a temporary event.
String
Last Modified Time
(Optional)
The date that will be used to filter the output to only features modified after that date.
Date
Input Filter Layers
(Optional)
The layers that will filter output to a smaller spatial subset. The input layers should be AIXM 5.1 feature types. This value should be in the same AIS geodatabase as the Input Aviation Workspace parameter value.
Feature Layer; Table
From Time
(Optional)
The starting time that will be applied to the output message for a given feature that is being exported for the field validTime\TimePeriod\beginPosition when the corresponding database value ValidFrom_Date is missing, or to featureLifetime\TimePeriod\beginPosition when the corresponding database value FeatureFrom_Date is missing.
This parameter will be used differently depending on the Export Type parameter value as follows:
  • Baseline—The parameter will be honored only when the actual database record does not have the FeatureFrom_Date or ValidFrom_Date attributes populated.
  • Snapshot—The parameter value provided will be exported regardless of the FeatureFrom_Date and ValidFrom_Date attributes in the database.
  • Permanent Delta—The parameter will be honored only when the actual database record does not have the FeatureFrom_Date or ValidFrom_Date attributes populated.
  • Temporary Delta—The parameter will be honored only when the actual database record does not have the FeatureFrom_Date or ValidFrom_Date attributes populated.
Date
To Time
(Optional)
The ending time that will be applied to the validTime\endPosition and featureLifetime\endPosition fields in the output message types for any missing ValidTo_Date or FeatureTo_Date field values in the features to export. The value will be converted to UTC. If no value is provided, the current system date and time in UTC will be applied to the missing field values in the output message.
This parameter is only valid when the Export Type parameter is set to Temporary Delta.
Date
Validate Output
(Optional)
Specifies whether the exported message will be validated for the XML format. You must be connected to the internet for validation to succeed.
  • Aktiviert—The exported message will be validated for the XML format.
  • Deaktiviert—The exported message will not be validated for the XML format. This is the default.
Boolean
(Optional)
The output XML validation log file.
File
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
