Generate OIS Intersection (Aviation Tools)
Zusammenfassung
Creates the most restrictive (lowest) surfaces within the extent of all collective surfaces. Obstruction identification surfaces (OIS) determine objects that are vertical obstructions. An object is considered a vertical obstruction if it penetrates the OIS surface. Surfaces are used to support planning and design activities.
Many airports have more than one runway and each runway has a set of obstruction identification surfaces. Supporting automatic generation of subsurfaces that constitute the overlapping portions of surfaces can produce a better visualization and a more accurate analysis for an airport. To generate a single set of surfaces, multiple sets of surfaces are needed. This tool creates surfaces as multipatch features.
Verwendung
  • The Input OIS Features parameter value must be z-enabled.
  • The Output OIS Features parameter value must be z-enabled.
  • All of the Input OIS Features parameter values must have the same projected coordinate system.
Parameter
Input OIS Features
The input OIS features. The feature class must be a multipatch.
Feature Layer
Output OIS Features
The updated feature class containing the meshed OIS with the lowest z-value.
Feature Layer
Create Multipart Feature
(Optional)
Specifies whether multipart features will be created in the output. Multipart features are composed of more than one physical part that only references one set of attributes.
  • Aktiviert—Multipart features will be created. This is default.
  • Deaktiviert—Adjacent triangulated multipart features will be created as individual features.
Boolean
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
  • Basic: No
  • Standard: Requires Airports or ArcGIS Aviation Charting
  • Advanced: Requires Airports or ArcGIS Aviation Charting
