Kriterieneigenschaften festlegen (Business Analyst Tools)
Zusammenfassung
Definiert Parameter für Kriterien.
Verwendung
  • Sie können das Werkzeug Eignungsanalyse-Layer erstellen verwenden, um den Analyse-Layer zu erstellen.
  • Alle Kriteriengewichtungen müssen zusammen 100 Prozent ergeben.
  • Der Einfluss der Kriterien kann positiv oder invers sein.
  • Wenn die Option Ideal des Parameters Kriterieneigenschaften angegeben wird, muss für Idealer Wert ein Wert eingegeben werden.
Parameter
Eingabe-Eignungsanalyse-Layer
Der Eignungsanalyse-Layer, der in der Analyse verwendet wird.
Feature Layer; Group Layer
Die Eingabe-Features, die zum Einrichten der Kriterieneigenschaften verwendet werden.
Spalten der Wertetabelle:
  • Criterion—The field, point, or variable that will be used to calculate the suitability score.
  • Title—The name of the criteria.
  • Weight—The influence a criteria value has on the overall suitability score. The number must be greater than or equal to 0.
  • Influence—An example of a positive influence is as follows: You want a site to score higher if it has a greater number of households holding graduate or professional degrees. An example of an inverse influence is as follows: A lower median home value is more desirable, as it is indicative of greater home affordability. An example of an ideal influence is a search for areas within a range of values.
    • Positive—The higher the criteria value, the higher the suitability score.
    • Inverse—The lower the criteria value, the higher the suitability score.
    • Ideal—The closer to the ideal value, the higher the suitability score.
    • Target—The closer to the target value, the higher the suitability score.
  • Ideal Value—The closer the criteria value is to the ideal value, the higher the suitability score.
  • Minimum Value—A numeric value that sets a hard limit for the criteria lower bound.
  • Maximum Value—A numeric value that sets a hard limit for the criteria upper bound.
  • Enabled—Specifies whether to include the criteria in the final suitability score.
Value Table
Voreingestellte Methode
(Optional)
Gibt die Vorverarbeitungs- und Kombinationsmethode an, die bei der Berechnung des Endergebnisses verwendet wird.
  • Combine Values—The sum of scaled values with scores representing the distribution of values for each criterion will be used. This is the default.
  • Compound Differences—The geometric mean of the scaled values will be used.
  • Custom—User-defined preprocessing and combination methods will be used.
String
Vorverarbeitungsmethode
(Optional)
Gibt die Methode an, die zum Konvertieren der Eingabevariablen in einen standardisierten Maßstab verwendet werden soll.
  • Minimum-maximum—Variables will be scaled between 0 and 1 using the minimum and maximum values of each variable. This is the default.
  • Percentile—Variables will be converted to percentiles between 0 and 1.
  • Z-score—Each variable will be standardized by subtracting the mean value and dividing by the standard deviation.
  • Raw—The values of the variables will be used without change.
String
Kombinationsmethode
(Optional)
Gibt die Methode an, die zum Kombinieren der skalierten Variablen in einen einzelnen Wert verwendet werden soll.
  • Sum—The values will be added. This is the default.
  • Mean—The arithmetic (additive) mean of the values will be calculated. This is the default.
  • Product—The values will be multiplied. All scaled values must be greater than or equal to zero.
  • Geometric Mean—The geometric (multiplicative) mean of the values will be calculated. All scaled values must be greater than or equal to zero.
String
Maßstab des Endergebnisses
(Optional)
Gibt die Methode an, die zum Skalieren des kombinierten Wertes verwendet wird. Dieser Parameter bestimmt das Endergebnis.
  • Method 0-1—The final score will be calculated with the lowest value of 0 and the highest value of 1.
  • Method 0-100—The final score will be calculated with the lowest value of 0 and the highest value of 100.
  • None—The data will not be scaled. This is the default.
String
Abgeleitete Ausgabe
Ausgabe-Eignungsanalyse-Layer
Der Name des Eignungsanalyse-Layers, der der Karte hinzugefügt wird.
Umgebungen
Aktueller Workspace
Lizenzierungsinformationen
  • Basic: Erfordert Business Analyst
  • Standard: Erfordert Business Analyst
  • Advanced: Erfordert Business Analyst
