Apply Feature Level Metadata (Topographic Production Tools)
Zusammenfassung
Applies values from a metadata record in the FeatureLevelMetadata table to selected features that have matching attribute fields.
Verwendung
The Metadata Favorite parameter value is a record in the FeatureLevelMetadata table. The tool will apply a record's associated values to corresponding attributes for the specified features in the Input Features parameter.
The FeatureLevelMetadata table is included with the ArcGIS Topographic Mapping product data files.
The field types in the FeatureLevelMetadata table must match the field types in the feature layers being updated. If they don't, the tool will fail with an error message indicating that the field types must match before processing.
Parameter
| Beschriftung | Erläuterung | Datentyp |
Input Features |
The inputs to which the Metadata Favorite parameter value will be applied. |
Feature Layer |
Input Metadata Table |
The path to the metadata table containing the records that will be used to populate attributes. |
Table View |
Metadata Favorite |
The record that will be used to populate attributes. The available options depend on the records available in the metadata table. |
String |
Abgeleitete Ausgabe
Updated Features |
The Input Features layer with updated attributes. |
Feature Layer; Feature Class |
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
- Basic: No
- Standard: Requires Topographic Mapping
- Advanced: Requires Topographic Mapping
