Download Job Files (Topographic Production Tools)
Zusammenfassung
Downloads and extracts the latest version of the job files from a topographic production server for manual operations.
Achtung:
This tool is intended for use with Topographic Production workflows and is designed to be run as a step in an ArcGIS Workflow Manager workflow. Workflow Manager must be properly configured to use this tool.
Verwendung
The active portal in ArcGIS Pro must be the portal that hosts the ArcGIS Workflow Manager service and Topographic Production service items. You must sign in to ArcGIS Pro with the account that has access to both services.
Accounts with administrator access can download files for any job item, and accounts without administrator access can only download the files for their own job items.
Hinweis:
The account assigned to the ArcGIS Workflow Manager Server job must be the account that created the job running on the Topographic Production service.
The topographic mapping job item must be paused on the server for this tool to run.
Job files are uploaded to the location specified in the
local_job_folderextended property of the Workflow Manager job. Accounts with administrator access can update this property's value.
Parameter
| Beschriftung | Erläuterung | Datentyp |
Service Item |
The unique name or identifier of the Workflow Manager service item on the portal with topographic production capabilities. Available Workflow Manager item options depend on the active portal in ArcGIS Pro. |
String |
Job Identifier |
The unique name or identifier of the currently active topographic product job. Available job item options depend on the Service Item parameter value. |
String |
Abgeleitete Ausgabe
Output Job Location |
The output location where the job files will be downloaded and extracted on the local machine. |
Folder |
Umgebungen
Dieses Werkzeug verwendet keine Geoverarbeitungsumgebungen.
Lizenzierungsinformationen
- Basic: No
- Standard: Requires Topographic Mapping
- Advanced: Requires Topographic Mapping
