Generate Location Diagram Features (Topographic Production Tools)
Zusammenfassung
Generates location diagram features for a Joint Operations Graphic (JOG), Operational Navigation Chart (ONC), or Tactical Pilotage Chart (TPC) map sheet. The location diagram must include JOG_Index features, WAC_Index features, ONC_Index features, or LandPoly features for the area surrounding the processed sheet.
Hinweis:
A product data file installer is available for ArcGIS Topographic Mapping. The product files contain a geodatabase named MapIndex.gdb that is necessary for generating features used in this tool.
Verwendung
  • At a minimum, the following feature classes will be generated in the target feature dataset:
    • LD_AOI—This feature class will store the extent of the entire diagram, a 5-by-5 grid, as one feature.
    • JOG_AOI—This feature class will store the Area of Interest parameter value at the center of the 5-by-5 grid from the selected sheet.
    • JOG_SHEETS_A—This feature class will be generated to support labeling and display requirements.
    • JOG_SHEETS_L—This feature class will be generated to support labeling and display requirements.
    • JOG_ONC—This feature class will be generated if ONC_Index features are provided.
    • JOG_WAC—This feature class will be generated if WAC_Index features are provided.
    • JOG_COAST_A—This feature class will be generated if input land features are provided.
    • JOG_COAST_L—This feature class will be generated if input coastline features are provided.
  • The Area of Interest parameter value must have only one selected feature.
  • If the input feature dataset contains existing feature classes, they will be deleted before the tool generates location diagram features.
Parameter
Input Feature Dataset
The feature dataset that will contain the location diagram feature classes. The tool will create these features classes if they do not exist.
Feature Dataset
Area of Interest
A polygon feature layer with a single selected feature that will be used to identify the center and surrounding areas of interest.
Feature Layer
Sheet Identifier Field
An attribute field that will be used to identify the generated sheet features. The default value of JOG_SHEET will be used if the field is present in the layer provided for the Area of Interest parameter value. Otherwise, provide a different field.
Field
WAC Features
The World Aeronautical Chart features that will be used to generate the location diagram feature classes in the input geodatabase. The default path is specified for this parameter if the Topographic Mapping product files are installed.
Feature Layer
ONC Features
The ONC features that will be used to generate the location diagram feature classes in the input geodatabase. The default path is specified for this parameter if the Topographic Mapping product files are installed.
Feature Layer
Land Features
The land features that will be used to generate the location diagram feature classes in the input geodatabase. The default path is specified for this parameter if the Topographic Mapping product files are installed.
Feature Layer
Specification
(Optional)
Specifies the type of map product for which the location diagram features will be generated.
  • JOG—The location diagram features for a Joint Operations Graphic will be generated. This is the default.
  • ONC—The location diagram features for an Operational Navigation Chart will be generated. This option activates the TPC Features parameter, Smoothing Tolerance parameter, and Hydro Settings (optional) category containing the following parameters: Hydro Line Features, Hydro Area Features, Minimum Hydro Line Length, Minimum Hydro Line Spacing, Minimum Hydro Area Length, and Minimum Hydro Area Width.
  • TPC—The location diagram features for a Tactical Pilotage Chart will be generated. This option activates the Smoothing Tolerance parameter and the Hydro Settings (optional) category containing the following parameters: Hydro Line Features, Hydro Area Features, Minimum Hydro Line Length, Minimum Hydro Line Spacing, Minimum Hydro Area Length, and Minimum Hydro Area Width.
String
TPC Features
(Optional)
The TPC features that will be used to generate the location diagram feature classes in the input geodatabase. This parameter is available when generating location diagram features for an ONC map product.
Feature Layer
Smoothing Tolerance
(Optional)
The tolerance that will be used by the smoothing algorithm. The larger the value, the more generalized the output location diagram features. This parameter is available when generating location diagram features for ONC or TPC map products. The default is 0.002 decimal degrees.
Linear Unit
Hydro Line Features
(Optional)
The hydrology line features that will be used to generate the output of a thinned hydrology dataset. Only the output features will be generalized through this thinning process. This parameter is available when generating location diagram features for ONC or TPC map products.
Feature Layer
Hydro Area Features
(Optional)
The hydrology area features that will be used to generate the thinned hydrology dataset. Only the output features will be generalized through this thinning process. This parameter is available when generating location diagram features for ONC or TPC map products.
Feature Layer
(Optional)
The minimum length that will be used to eliminate hydrology features. The tool will thin hydrology features that have a length less than this value. This value will be used when generalizing input hydro lines and areas. This parameter is available when generating location diagram features for ONC or TPC map products.
Linear Unit
(Optional)
The shortest distance between hydrographic segments that will display at the output scale. If the spacing between two parallel trending features is smaller than this value, one of the features will be hidden. This parameter defines the density of the resulting thinned hydrography. It should correspond to the distance between two parallel trending features that is visually significant to include at the final scale. When the density of features is too high (that is, the features are too closely spaced), at least one feature will be hidden. This can result in important features or features longer than the Minimum Hydro Line Length value being hidden. This parameter is available when generating location diagram features for ONC or TPC map products.
Linear Unit
(Optional)
The length that will be used to split and classify hydrographic polygons as short or long. Polygons will be split at any location where the edge-to-edge distance is equal to this value. This parameter is available when generating location diagram features for ONC or TPC map products.
Linear Unit
(Optional)
The width that will be used to split and classify hydrographic polygons as narrow or wide. Polygons will be split at any location where the edge-to-edge distance is equal to this value. This parameter is available when generating location diagram features for ONC or TPC map products.
Linear Unit
Minimum Island Area
(Optional)
The minimum area necessary for an island or hole to be included in the resulting features.
Areal Unit
Abgeleitete Ausgabe
Modified Feature Dataset
The updated input feature dataset that contains the location diagram feature classes.
Feature Dataset
Umgebungen
Scratch Workspace
Lizenzierungsinformationen
  • Basic: No
  • Standard: No
  • Advanced: Requires Topographic Mapping
