Create Range Rings Interactively
This workflow demonstrates how to interactively create range rings by clicking the map.
You can create range rings and radials on a map. Range rings can be created interactively or from a known center point and distance between rings values. When creating range rings from known distances between rings, the rings can be drawn at a fixed interval based on a distance from the origin point or cumulatively based on a distance from the previous ring.
Interactive Range Ring
Prerequisites
  • You must have a project with a map open.
Tools and commands used
Steps
  1. Click the Map tab.
  2. Click Distance and Direction in the Inquiry group .
    The Distance and Direction pane opens.
  3. Click the Rings tab.
  4. Click Map Point Tool
  5. Click a location on the map to designate the center point of the ring or rings.
  6. In the Ring Type drop-down list, click Interactive.
  7. Click the map to designate the diameter of the next ring. Add rings as necessary and double-click to finish.
    Range Rings are created and added to the map.
Alternate workflows
Back to top
