Edit sketch geometry
Use the Edit Vertex tool to edit unfinished sketch geometry while you create a feature using a construction tool. The workflow is comparable to editing vertices. This tool is available on the segment construction toolbar.
When you use vertex editing, consider the following:
  • Turn vertex editing off to draw a closed polyline feature with the last segment vertex at the same location as the first vertex.
  • To automatically turn this mode on or off, configure this setting in project options.
To edit sketch geometry, complete the following steps:
  1. If unfinished feature geometry is not currently active, create at least two unfinished segments using a polyline or polygon feature construction tool.
  2. On the segment construction toolbar, click Edit Vertex and confirm that it is turned on.
    Edit Vertex tool
  3. To edit a vertex, hover over the vertex until the vertex pointer appears, and drag the vertex with the pointer, or right-click it and click one of the following commands:
    M value
    Edit vertex m-values for polylineZM features.
    Add Add
    Add a vertex with the same x-, y-, z- and m-value as the right-clicked vertex.
    Delete Close
    Delete the right-clicked vertex.
    Delta XYZ Move
    Move the right-clicked vertex by the specified x, y, z distances.
    Absolute XYZ Move To
    Move the right-clicked vertex to the specified x, y, z location.
    Reverse Direction Reverse Direction
    Change the direction of a sketch. The first vertex in the sketch becomes the last vertex.
    Trim Beginning To Vertex Trim Before
    Delete all vertices in a sketch from the start vertex to the right-clicked vertex.
    Trim End To Vertex Trim After
    Delete all vertices in a sketch from the right-clicked vertex to the end vertex.
  4. To edit a segment, hover over the segment until the segment pointer appears, and drag the segment with the pointer, or right-click it and click one of the following commands:
    Add Add
    Add a vertex at the right-clicked location.
    Change segment
    Change the right-clicked segment to a line, an arc, or a Bezier curve.
    This command is available only for line feature sketches.
    Trim to Length Trim to Length
    Change the total length of a sketched line to the specified value.
    • A positive value preserves the location of the first vertex.
    • A negative value preserves the location of the last vertex.
  5. Click Finish , or press the F2 key when you're finished.
Back to top
