Segment construction tools
Segment construction tools create contiguous linear and curvilinear segments. They are available on the construction toolbar when a polyline or polygon construction tool is active. The toolbar is also available above the context menu when you right-click a map.
Tool
Line Line
Create straight line segments between vertices by clicking or typing the vertex locations.
Right Angle Line Right Angle Segment
Create straight line segments at 90-degree angles between vertices by clicking or typing the vertex locations.
Arc Segment Arc Segment
Create circular arc segments by clicking or typing the location for a start point, a point through which the arc passes that defines the radius, and an endpoint. To specify a numeric radius value, press R.
Endpoint Arc Segment Arc Segment
Create circular arc segments by clicking or typing the location for a start point, an endpoint, and a point through which the arc passes that defines the radius.
Tangent Curve Segment Tangent Arc
Create circular arc segments that are tangent to the previous segment using two points.
Bezier Curve Segment Bezier Curve
Create nonlinear Bézier curved segments using control points and handles to shape the angle and height of the curve.
Trace Trace
Create segments that follow another feature by using the pointer to trace the boundary of the feature.
Streaming Streaming
Create free-form segments by streaming vertices with the pointer. Press O to check the Smooth setting and convert the segments to Bézier curves when you finish the feature.
Back to top
