ArcGIS Data Interoperability for Server system requirements
The extension requires ArcGIS Server or ArcGIS Enterprise, which must be installed with .NET Extension Support enabled. If you installed ArcGIS Server or ArcGIS Enterprise without .NET Extension support, you must install the correct Microsoft .NET Framework version and enable it by modifying your installation.
For more information about installing .NET Extension Support, see ArcGIS Server system requirements.
The extension must be installed on each machine that will publish geoprocessing services or hosted web tools in your ArcGIS Server - whether its a stand-alone GIS Server or a federated ArcGIS Server.
Feature Manipulation Engine
The uses the Feature Manipulation Engine (FME) technology from Safe Software. To share Spatial ETL (extract, transform, load) tools authored using ArcGIS Pro as web tools to ArcGIS Enterprise, both must use the same version of FME. The following table lists the version of FME included with each version of ArcGIS Pro and ArcGIS Server:
| ArcGIS Pro Version | ArcGIS Server Version | FME Version Included | FME Build |
| ArcGIS Pro 3.8 | ArcGIS Server 12.2 | 2026.3 | 26589 |
| ArcGIS Pro 3.7 | ArcGIS Server 12.1 | 2026.1 | 26103 |
| ArcGIS Pro 3.6 | ArcGIS Server 12.0 | 2025.1.2.0 | 25630 |
| ArcGIS Pro 3.5 | ArcGIS Server 11.5 | 2025.0.0.0 | 25208 |
| ArcGIS Pro 3.4 | ArcGIS Server 11.4 | 2024.1.2.1 | 24626 |
| ArcGIS Pro 3.3 | ArcGIS Server 11.3 | 2024.0.1.0 | 24202 |
| ArcGIS Pro 3.2 | ArcGIS Server 11.2 | 2023.1.1.1 | 23636 |
| ArcGIS Pro 3.1 | ArcGIS Server 11.1 | 2022.2.1.0 | 22776 |
When requesting support, please read the ArcGIS Enterprise Lifecycle page and identify the applicable status for your version of ArcGIS Server.
ArcGIS Server account
The ArcGIS Server account is the operating system account that you specify when you install ArcGIS Server. To securely share Spatial ETL tools using the extension, sign in to each ArcGIS Server machine that will host the tools using the ArcGIS Server account.
Learn more about the ArcGIS Server account.
Deployment scenarios
Spatial ETL tools can be shared as web tools or geoprocessing services to both federated or stand-alone ArcGIS Server sites, respectively, using the extension.
