Install the ArcGIS Data Interoperability for Server
The following steps will guide you through the extension installation process.
Installation prerequisites include the following:
Verify that the system meets the system requirements.
Obtain an authorization file for the machine on which you are installing the ArcGIS Data Interoperability for Server extension.
Sign in as a user with administrative privileges.
The extension download provides the option to start the installation after the files have been extracted. To manually launch the setup program, use setup.exe.
Click Next in the Welcome to the ArcGIS Data Interoperability for Server Setup Program pane of the installation wizard.
The Master Agreement dialog box appears.
Review the master agreement and accept it or close the dialog box if you do not agree with the terms.
Click Next.
The Destination Folder dialog box appears.
Specify the installation location and click Next.
The Ready to install the Program dialog box appears.
Click Install to begin the installation.
Once the installation is complete, the InstallShield Wizard Completed dialog box appears.
Click Finish.
To install the extension in an ArcGIS Server multi-machine deployment, run this installation wizard on each machine in the site.
