ArcGIS Places - United States
Esri provides three ArcGIS Places datasets for Puerto Rico and the United States sourced from data supplied by Data Axle and SafeGraph. See Compare United States ArcGIS Places to compare these datasets.
  • Business Locations—Sourced from data supplied by Data Axle. This dataset contains approximately 13 million point-based locations of individual businesses, including attributes such as the company name, address, and business or industry category. It can be used to provide information about a location, a business, or the regional distribution of businesses by category. See the Data Axle topic for a full list of available business attributes.
    This data cannot be used for direct mailing purposes.
    The following image shows business locations for auto repair and maintenance facilities around Las Vegas, Nevada, USA:
    A point-location map of auto repair and maintenance facilities around Las Vegas, Nevada, USA
  • Business Summary—Derived from the Business Locations dataset, the Business Summary dataset contains aggregated counts of businesses by type within defined areas. It is useful for quantifying business types in a region. Business Summary values can be estimated for any user-defined polygon—such as rings and drive times—using Esri data enrichment capabilities in various ArcGIS products.
    Records flagged as a kiosk are not included in Business Summary calculations. Examples of kiosks include ATMs, electric charging stations, donation drop boxes, mailboxes, and video rental kiosks. Kiosk-flagged records can be found in the Business Locations point-based dataset but are omitted from Business Summary calculations.
    The following image shows the Business Summary of the number of auto repair and maintenance facilities by ZIP code surrounding Las Vegas, Nevada, USA:
    Business Summary map showing the number of auto repair and maintenance facilities by ZIP code surrounding Las Vegas, Nevada, USA.
    In June 2026, Esri discontinued support for Standard Industrial Classification (SIC) categories in Business Summaries. North American Industry Classification System (NAICS) categories continue to be supported.
  • Points of Interest—The Points of Interest datasets sourced from data supplied by SafeGraph contain approximately 109,000 Puerto Rican points of interest and more than 19 million points of interest in the United States. Available attributes include the place-name, location, an industrial classification code, and brands (when applicable). See the SafeGraph topic for a full list of available points of interest attributes.
Tip:
Learn more about using ArcGIS Places datasets in Esri software in the Where to find ArcGIS Data and Introduction to ArcGIS Places topics.
Release date
  • The Business Locations and Business Summary datasets were updated in November 2026 with vintage August 2026 data from Data Axle.
  • The Points of Interest dataset was updated in November 2026 with July 2026 data from SafeGraph.
Methodology
See the Esri Business Locations and U.S. Business Summary methodology topic to learn how this dataset was created and is updated.
Location accuracy
The Business Locations, Business Summary, and Points of Interest datasets use geographic point data derived from latitude-longitude coordinates. Most locations can be located to rooftop or street centerline accuracy, but some can only be placed to city or ZIP/postal code centroid-level accuracy. Therefore, not all points have an exact location.
Sample questions and use cases
The Esri ArcGIS Places datasets can be used to determine which businesses are well represented in an area and which are under-represented, or to compare and analyze data across companies, regions, or industries effectively. ArcGIS Places data also supports activities such as market analysis, site selection, customer segmentation, and competitive analysis.
Sample questions that can be answered using the Esri ArcGIS Places datasets may include the following:
  • What is the overall coffee shop density in Shreveport?
  • Which industries are the most prevalent in southwestern St. Louis?
  • How many similar businesses are near this address? Can I categorize them by NAICS code?
  • How many gas stations are in this ZIP code?
  • What are the total sales for similar restaurants in this neighborhood?
Example use cases for Esri ArcGIS Places data include the following:
Retail expansion
A retail chain can use the Esri ArcGIS Places datasets to find the best location for a new store by identifying areas with high concentrations of potential customers based on existing target demographics and the current retail landscape.
Evaluate the competitive landscape
Companies can use Esri ArcGIS Places data to evaluate the competitive landscape around existing or proposed store sites by mapping the locations of their competitors. This can help determine the retail opportunity for any location and estimate a new store’s sales volume.
Related links
Refer to the following content:
