Install and authorize named user licenses
To use Drone2Map with a named user license, you need an ArcGIS Online subscription or Portal for ArcGIS account with a Drone2Map or Reality Mapping license provisioned. Follow the instructions below to access, download, install, and authorize Drone2Map based on your configuration.
Free trial with ArcGIS Online
To request a Drone2Map evaluation, contact your account representative.
Download
If you have an ArcGIS Online or Portal for ArcGIS account, you can download Drone2Map from My Esri.
Review the Drone2Map system requirements to verify operating system and hardware prerequisites and confirm your system meets the requirements before installing ArcGIS Drone2Map.
Download Drone2Map from My Esri.
To download, your Esri account must be connected to your organization with the appropriate permissions.
Install Drone2Map
To install Drone2Map, complete the following steps:
Start the Drone2Map installation program and click Next when you're ready to proceed.
Review the license agreement and accept it if you agree. Click Next to continue with the installation. If you do not agree with the terms of the license agreement, close the installation program.
Click Change to specify the installation folder or Next to accept the default location.
Click Install to start the installation.
Click Finish to close the wizard when the installation completes.
ArcGIS Drone2Map has multiple optional installation packages that can be installed. For more information, see Optional installation packages.
Start Drone2Map with a Named User license
You must have an ArcGIS Online or Portal for ArcGIS account that is assigned a Creator, Professional or Professional Plus user type with a Publisher role before using Drone2Map. The process for starting Drone2Map with a Named User license with ArcGIS Online is different than that of a Named User license with Portal for ArcGIS. With a Named User license, you can sign in to any machine with Drone2Map installed. Contact your license administrator if you do not have an account or if your account is not authorized. For more information, see Manage Drone2Map licenses.
Sign in to a Named User account with ArcGIS Online
To sign in to Drone2Map with an ArcGIS Online Named User account, complete the following steps:
Start Drone2Map.
In the Sign In window, provide your account credentials.
Optionally, check the Sign me in automatically check box if you want to sign in with your credentials automatically when you start Drone2Map.
This option is enabled by default. Uncheck the Sign me in automatically check box if you prefer to provide your credentials each time you start Drone2Map.
Click Sign in.
Sign in to a Named User account with Portal for ArcGIS
To sign in to Drone2Map with a Portal for ArcGIS Named User account, complete the following steps:
Start Drone2Map.
In the Sign In window, click Configure your licensing options.
If you are already signed in to a portal, you can access the Configure your licensing options tool from an open Drone2Map project or from the start page. From the new project page, click Settings, or, from an open project, on the ribbon, click the Project tab. Click the Licensing tab, and click Configure your licensing options.
The Licensing dialog box appears.
On the Licensing dialog box, choose Authorize Drone2Map using your ArcGIS Enterprise portal and type the portal URL.
Click OK.
You must restart Drone2Map for your changes to take effect. When you start a new session, sign in to the portal you specified in the previous step.
Your authorizing portal may be configured to use Integrated Windows Authentication (IWA) or a Security Assertion Markup Language (SAML)-compliant provider. See use Integrated Windows Authentication or Configure a SAML-compliant identity provider with your portal for information on configuring your portal. To sign in to Drone2Map using these configurations, follow the same steps as above to configure your licensing options. If you're using IWA, enter your Microsoft Windows username and password when prompted. If using a SAML-compliant identity provider, click to sign in with your SAML-compliant provider account.
Get Drone2Map software updates
When Esri releases an update to Drone2Map, a notification appears when you start the application. Click the notification message to learn more about the update and start the update process. To check for updates in the middle of a session, click the Project tab, click About, and click Check for Update. If updates are available, run the update process.To learn more about notifications, see: Notifications
Block update notifications
As an administrator, you can block automatic update notifications for a per-machine installation of Drone2Map. Browse to the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Esri\Drone2Map\Settings and set the value of CheckForUpdatesAtStartup to 0.
