Processing options
In Drone2Map, you can adjust the processing options for a project to customize it. You can run steps independently, minimizing the time required to generate the desired products; however, you must run the initial step at least once.
Use the Processing Options window to configure which steps will run, the settings for each step, and which products will be created. To open the window, on the ribbon, on the Home tab, in the Processing group, click Options.
General
On the General tab, you can adjust the quality and resolution of output products. You can also save intermediate outputs and define how much processing power is used when generating those products.
  • Image Information—Displays information about the number of images and total gigapixels in the current project.
    • Enabled Images—Total number of images with a status of Enabled to be used in processing.
    • Gigapixels—Number of gigapixels used in the current project. See the note below for more information.
When assigned a Professional or Professional Plus user type, there is no project image size limit. Otherwise, combined project imagery size is limited to 300 gigapixels. Calculate the size by multiplying the number of images by image megapixel size and dividing by 1,000.
For example, a project with 400 13-megapixel imagery is (400 x 13)/1,000 = 5.2 gigapixels.
  • Dense Matching
    • Point Cloud Density—This is the density of the point cloud used to derive the level of geometric detail of the resulting reconstruction. Increasing this value improves edge sharpness of features and increases processing time.
      Digital terrain model (DTM) products are based on the digital surface model (DSM) point cloud and are generated at five times the DSM resolution.
      • Ultra—Highest level of density point cloud. Use for final products that require the highest detail possible.
      • High—High level of density point cloud. This is the recommended setting for most projects. This is the default.
      • Rapid—Lowest level of density point cloud. It is suitable for quick projects or testing.
    • Use Tie Points in Surface Reconstruction—When enabled, the tie points generated during the Adjust Images step will be used as an input for the surface reconstruction processing step. This option cuts down on the time needed to run the surface reconstruction step, but can be disabled if needed.
  • Project Resolution—Defines the spatial resolution used to generate output products.
    • Automatic (default)—Uses the resolution of your source imagery.
      • 1x (default)—Recommended image scale value, full resolution of the source images.
      • 4x—Recommended for very large projects with high overlap; 4x Source Resolution can be used to speed up processing, which often results in slightly reduced accuracy, as fewer features are extracted. This scale is also recommended for very blurry or very low-textured images.
    • User Defined—Allows you to manually define the resolution value in centimeters or pixels for the GSD. This scale allows you to select the Ultra or High point cloud settings.
  • Hardware—Sets the number of central processing unit (CPU) threads to be used during processing.
    • CPU Threads—The number of CPU threads dedicated to processing your project. Slide the bar to the left or right to adjust the number of CPU threads.
    • CUDA Compute Version—The NVIDIA CUDA compute capability of the graphics processing unit (GPU) installed in the system. CUDA computation is used in the processing of deep learning workflows such as automated ground control point detection and the generation of Gaussian splat products. If the installed hardware does not support the minimum required CUDA compute version, this information will not appear in the Processing Options window. For more on GPU requirements, see ArcGIS Drone2Map system requirements
    • GPU VRAM—The total amount of available GPU VRAM. A minimum of 8 GB of VRAM is required for deep learning workflows.
  • Locations—Lists file path locations of the project file, source images, and project log file.
    • Project—The location of the current project in the file system. Click the link to open the file location.
    • Images—The location of the source images used in processing the current project. Click the link to open the image location.
    • Log File—The location of the project log file. Click the link to open the file location. This file is useful when troubleshooting issues with Drone2Map.
Adjust Images
On the Adjust Images tab, the options allow you to define key adjustments to be used in the block adjustment process, tie point matching, and point cloud generation.
  • Adjustment Mode—Defines the adjustment mode that is used during the Adjust Images step. Different modes can help to reduce the occurrence of dropped images depending on the subject matter.
    • Standard—Suitable for images with medium to high contrast, texture, manmade features, and sparse vegetation.
    • Challenging—Suitable for images with low contrast and texture, sparse manufactured features, and high percentage of dense vegetation or water bodies. This option is more process intensive when compared to standard mode.
  • Fix Image Location for High Accuracy GPS (RTK and PPK)—When enabled, this option changes the Matching Neighborhood setting to Small (Optimized). This option is used only for imagery acquired with high-accuracy, differential GPS, such as real-time kinematic (RTK) or postprocessing kinematic (PPK). If this option is checked, the process only adjusts the orientation parameters of the imagery and leaves the GPS measurements fixed. However, this setting assumes that all the image locations collected by your RTK drone are accurate. If one or more images are determined to not be accurate enough to fix and still return a good adjustment solution, all images will be adjusted to achieve a best fit calibration.
    This option should only be used with checkpoints and not ground control points. Having this option and ground control linked during the adjustment step can produce accuracy errors.
  • Use Image Orientations—When enabled, the orientation data from the source images is used and the initial orientation adjustment during the Adjust Images step is skipped. This option can be used when yaw, pitch, and roll are present in the image metadata, or omega, phi, and kappa values are imported from an external geolocation file. Instead of the aerial triangulation (AT) calculating the initial orientation, Drone2Map will use the yaw, pitch, and roll of the images to calculate the initial orientation of the imagery.
    If orientation information (yaw, pitch, roll or omega, phi, kappa) is present in the images, Drone2Map will automatically enable this option. The orientation information from the images will then be used for the initial orientation adjustment processing. This reduces processing during the Adjust Images step, decreasing processing time.
  • Initial Image Scale—This controls the way feature points are extracted. The project adjusts the value by default based on the template you chose when creating the project: 2D Products (1x) or Rapid (4x). More tie points are generated when the setting is closer to source resolution (1x), but the processing time also increases accordingly.
    • 1 (Original image size)—Recommended image scale value.
    • 1/2 (Half image size)—Recommended for projects using small images (for example, 640x320 pixels), because more features will be extracted, and it will assist with the accuracy of results.
    • 1/4 (Quarter image size)—Recommended for very large projects with high overlap; 4x source resolution can be used to speed up processing, which often results in slightly reduced accuracy, as fewer features are extracted. This scale is also recommended for very blurry or very low-textured images.
    • 1/8 (Eighth image size)—For very large projects with high overlap; 8x source resolution can be used to speed up processing, which usually results in slightly reduced accuracy, as fewer features are extracted.
  • Refine Adjustment—Specifies whether the camera model is further optimized using the selected image scale. If the Initial Image Scale image size is already at 1, there is no additional benefit. It is recommended that you check the Refine Adjustment box for final product generation. For doing quick quality adjustments, you can uncheck the setting.
    • Checked—The camera model is first estimated using the Initial Image Scale setting and further optimized using the selected image scale. This option produces the most accurate results.
    • Unchecked—The camera model is estimated using the Initial Image Scale setting with no additional optimization. This option produces the fastest results but may be less accurate.
    • 1 (Original image size)—Adjustment is performed at the original image size. This is the recommended image size.
    • 2 (Double image size)—The image is upscaled to twice the original size before attempting to extract feature points. This size is recommended for projects using small images (for example, 640x320 pixels), because more features can be extracted, which increases the accuracy of the results.
  • Max Tie Points—Specifies the maximum number of tie points per image allowed during the adjustment process. A lower number produces faster results at the expense of accuracy.
  • Matching Neighborhood—Determines the number of images from each search neighborhood that are used to compute image matches. A search neighborhood is the area between each of the four ordinal directions (northeast, southeast, southwest, and northwest). Larger neighborhood sizes increase processing times, but they also increase matches with neighboring images. If a high number of uncalibrated images is detected during initial adjustment, it is recommended that you increase the neighborhood size. Otherwise, use the default settings.
    • Small (Optimized)—An image is matched to the three closest images for each search neighborhood, a total of 9.
    • Medium—An image is matched to the six closest images for each search neighborhood, a total of 24.
    • Large—An image is matched to the 12 closest images for each search neighborhood, a total of 48.
    • X-Large (Slowest)—An image is matched to the 20 closest images for each search neighborhood, a total of 80.
  • Use Tie Points in Surface Reconstruction—Specifies whether tie points will be used in surface reconstruction.
    • Checked—Tie points will be used as input to surface reconstruction.
    • Unchecked—Tie points will not be used and full surface reconstruction is run.
  • Camera Calibration—Sets internal camera parameters used for image adjustment. If checked, the value is automatically taken from the Edit Camera pane. If a value is missing, the initial value is calculated from the EXIF data. If unchecked, the calibration is fixed to the values that are manually defined in the Edit Camera pane.
    • Focal Length—The focal length of the camera lens, measured in millimeters.
    • Principal Point—The offset between the fiducial center and the principal point of autocollimation (PPA). The principal point of symmetry (PPS) is assumed to be the same as the PPA.
    • K1,K2,K3—Konrady coefficients to calculate radial distortion.
    • P1,P2—Tangential coefficients to calculate distortion between the lens and image plane.
  • Auto Link Control—Uses deep learning models and tools to automatically detect, link, and integrate control markers with crosses and checkers into the adjustment process.
    • Auto Link Control Method—Defines the method used for the automatic link process. It is recommended that you review and revise control point links prior to creating products.
      • Auto Link—Control points are automatically detected and linked. A second adjustment is required to integrate the control points into the adjustment.
      • Auto Link and Adjust—Control points are automatically detected, linked, and integrated into the adjustment.
    • Cropped Image Size—Specifies the image area used to detect the control point. Increasing the size can improve detection accuracy when the initial estimated position is far from the actual location, but this may reduce performance.
    • Max Links—Sets the maximum number of images that can be automatically linked to each control point based on detection results.
    • Use Highest Score—Uses the highest score from the deep learning model to estimate the links in other images.
  • General Adjust Options—Controls general options used in the adjustment step.
    • Include True Ortho preview in processing report—If checked, a preview image of the True Ortho product is added to the image overlap graphic that is generated in the processing report.
    • Rolling Shutter Correction—If checked, the Adjust Images step will use rolling shutter correction to reduce distortions and inaccuracies caused by rolling shutter cameras.
    • Create Elevation Surface—If checked, an elevation surface will be created and added to the map from the adjusted solution points. The digital terrain model will be used as the elevation surface if enabled as a 2D product.
2D products
On the 2D Products tab, the following options allow you to adjust the processing options and desired outputs for True Ortho, digital surface model (DSM), and digital terrain model (DTM) images:
  • Image Collection—Defines the options for the Image Collection mosaic product.
    • Orthorectification Method—Elevation source used to orthorectify the mosaicked images.
      • None—No elevation source is used.
      • Solution Points—The elevation source is created from solution points generated during adjustment.
      • Sparse Point Cloud—The elevation source is created from a point cloud derived from the image collection.
      • Dense Point Cloud—The elevation source is created from a dense matching point cloud.
        To use the Dense Point Cloud option, a DSM product must first be present.
    • Depth Map Images—Supports detailed inspection workflows. When enabled, depth map files (.dm) will be generated alongside all the original project images in the folder in which they are stored.
    • Thumbnails—Generates thumbnails to be used in inspection workflows. Thumbnails appear in the pop-ups for drawn inspection features.
    • Color Balancing—Makes transitions from one image to an adjoining image appear seamless.
    • Seamlines—Sorts overlapping imagery and produces a smoother-looking mosaic.
    • Mosaic Candidates—Adds a Candidate column to the image collection that indicates if the image was considered to be a candidate that best represents the mosaic area. Possible values are 0 and 1, where 0 is not a candidate and 1 is a candidate.
  • True Ortho—Generates a True Ortho from the project's images. True Ortho products are high-resolution full nadir ortho images.
    • TIF—When checked, generates a True Ortho TIF from the project's images.
    • MRF—When MRF is checked, the True Ortho product will be generated in meta raster format (MRF). If MRF is checked and TIF is unchecked, a virtual raster tile (.vrt) file will still be created for visualization and added to the map. .mrf files are not added to the map by default and will appear within their own folder for the processed product.
    • CRF (Cloud Raster Format)—When CRF is checked, the True Ortho product will be generated in cloud raster format. If CRF is checked and TIF is unchecked, a .vrt file will still be created for visualization and added to the map. .crf files are not added to the map by default and will appear within their own folder for the processed product.
      • Merge Tiles—When checked, merges the tiles into a single True Ortho image. When using TIF format, the option can be unchecked to create a mosaic dataset of your tiles that can be used in tile-based processing.
      • Delete Tiles—When using TIF format, deletes True Ortho tiles after a single True Ortho is created.
  • Create DSM Point Clouds—Allows you to select the output formats for the DSM point cloud. The options are as follows:
    • SLPK—Creates a scene layer package (.slpk file).
    • LAS—Creates a lidar LAS file with x,y,z position and color information for each point of the point cloud.
    • Merge LAS Tiles—Merges LAS tiles into a single LAS file instead of the default individual LAS tile files.
    • Ground Classification—Modifies the way the DTM ground classification is performed.
      • Classify Ground—When checked, allows you to select and modify ground classification.
      • Method—Specifies the method that will be used to detect ground points.
        • Default—This method has a tolerance for slope variation that allows it to capture gradual undulations in the grounds topography that would typically be missed by the conservative option but not capture the type of sharp reliefs that would be captured by the aggressive option.
        • Aggressive—This method detects ground areas with sharper relief such as ridges and hilltops that may be ignored by the Default classification method. This method is used with the Reuse existing ground parameter checked. Avoid using this method in urban areas or flat, rural areas, as it may result in the misclassification of taller objects such as utility towers, vegetation, and portions of buildings as ground.
        • Conservative—When compared to other options, this method uses a tighter restriction on the variation of the ground's slope that allows it to differentiate the ground from low-lying vegetation such as grass and shrubbery. It is best suited for topography with minimal curvature.
      • Use Enhanced Detection—The most recent version of the ground-detection algorithm will be used. This option improves the handling of noise and outlier points, especially for photogrammetrically derived point clouds. It also produces better results and faster performance in most cases. This option is enabled by default.
      • Reuse Existing Ground—When checked, existing ground points will be accepted and reused without scrutiny and contribute to the determination of unclassified points. When unchecked, points that are not found to be a part of the ground will be reassigned a class code value of 1, which represents unclassified points.
      • Classify Low Noise—Noise points that are below the Minimum depth below ground (m) parameter threshold will be assigned a value of 7, which represents low noise.
        • Reuse Existing Low Noise—When checked, existing ground points will be reclassified. Points that are not found to be a part of the ground will be reassigned a class code value of 1, which represents unclassified points. When unchecked, existing ground points will be accepted and reused without scrutiny and contribute to the determination of unclassified points.
        • Minimum depth below ground (m)—Minimum depth value, measured in meters, for points to be considered low noise.
      • Classify High Noise—Noise points that are above the Maximum height above ground (m) parameter threshold will be assigned a value of 18, which represents high noise.
        • Reuse Existing High Noise—When checked, existing ground points will be reclassified. Points that are not found to be a part of the ground will be reassigned a class code value of 1, which represents unclassified points. When unchecked, existing ground points will be accepted and reused without scrutiny and contribute to the determination of unclassified points.
        • Minimum height above ground (m)—Minimum height value, measured in meters, for points to be considered high noise.
  • Digital Surface Model—Generates a DSM from the project images.
    • TIF—When checked, generates a TIF DSM from the project images.
    • MRF—When MRF is checked, the DSM product will be generated in MRF. If MRF is checked and TIF is unchecked, a .vrt file will still be created for visualization and added to the map. .mrf files are not added to the map by default and will appear within their own folder for the processed product.
    • CRF—When CRF is checked, the DSM product will be generated in cloud raster format (CRF). If CRF is checked and TIF is unchecked, a .vrt file will still be created for visualization and added to the map. .crf files are not added to the map by default and will appear within their own folder for the processed product.
      • Merge Tiles—When checked, merges the tiles into a single single DSM image. When using TIF format, the option can be unchecked to create a mosaic dataset of your tiles that can be used in tile-based processing.
      • Delete Tiles—When using TIF format, deletes DSM tiles after a single DSM is created.
    • Create Shaded Relief—Generates a shaded relief using the DSM.
      • Hillshade Type—Controls the illumination source for the hillshade.
        • Traditional—Calculates hillshade from a single illumination direction. You can set the Azimuth and Altitude options to control the direction of the light source.
        • Multidirectional—Combines light from multiple sources to represent an enhanced visualization of the terrain.
      • Azimuth—Azimuth is the sun's relative position along the horizon (in degrees). An azimuth of 0 degrees indicates north, east is 90 degrees, south is 180 degrees, and west is 270 degrees.
      • Altitude—Altitude is the sun's angle of elevation above the horizon and ranges from 0 to 90 degrees. A value of 0 degrees indicates that the sun is on the horizon, that is, on the same horizontal plane as the frame of reference. A value of 90 degrees indicates that the sun is directly overhead.
      • Z Factor—The z-factor is a scaling factor used to convert the elevation values for two purposes: to convert the elevation units (such as meters or feet) to the horizontal coordinate units of the dataset, which may be feet, meters or degrees; and to add vertical exaggeration for visual effect.
    • TIF—TIF is checked by default. When checked, this generates the Shaded Relief file in TIF format.
    • MRF—When checked, generates the Shaded Relief product in MRF. TIF format will also be checked and disabled when MRF is checked. This allows the creation of a TIF for visualization and use in sharing since MRF only supports generation.
    • CRF—When checked, generates the Shaded Relief product in CRF. TIF format will also be checked and disabled when CRF is checked. This allows the creation of a TIF for visualization and use in sharing since CRF only supports generation.
  • Create Contours—Generates contour lines using the DSM.
    • Contour Interval—Defines the contour line elevation interval in meters. It can be any positive value. The elevation interval must be smaller than the maximum–minimum altitude of the DSM.
    • Contour Base—Defines the relative altitude, which is used as a contour line base in meters.
    • Contour Z Factor—The contour lines are generated based on the z-values in the input raster, which are often measured in units of meters or feet. With the default value of 1, the contours will be in the same units as the z-values of the input raster. To create contours in a different unit than that of the z-values, set an appropriate value for the z-factor. Note that it is not necessary that the ground x,y and surface z-units be consistent for this tool. For example, if the elevation values in your input raster are in feet, but you want the contours to be generated based on units of meters, set the z-factor to 0.3048 (1 foot = 0.3048 meters).
    • Export Shapefile—Exports contour lines in shapefile format.
  • Digital Terrain Model—Generates a DTM from the project images.
    • TIF—When checked, generates a TIF DTM from the project images.
    • MRF—When MRF is checked, the DTM product will be generated in MRF. If MRF is checked and TIF is unchecked, a .vrt file will still be created for visualization and added to the map. .mrf files are not added to the map by default and will appear within their own folder for the processed product.
    • CRF (Cloud Raster Format)—When CRF is checked, the DTM product will be generated in CRF. If CRF is checked and TIF is unchecked, a .vrt file will still be created for visualization and added to the map. .crf files are not added to the map by default and will appear within their own folder for the processed product.
    • Create Shaded Relief—Generates a shaded relief using the DTM.
    • Create Contours—Generates contour lines using the DTM.
      • Contour Interval—Defines the contour line elevation interval in meters. It can be any positive value. The elevation interval must be smaller than the maximum–minimum altitude of the DTM.
      • Contour Z Factor—The contour lines are generated based on the z-values in the input raster, which are often measured in units of meters or feet. With the default value of 1, the contours will be in the same units as the z-values of the input raster. To create contours in a different unit than that of the z-values, set an appropriate value for the z-factor. Note that it is not necessary to have the ground x,y and surface z-units be consistent for this tool. For example, if the elevation values in your input raster are in feet, but you want the contours to be generated based on units of meters, set the z-factor to 0.3048 (since 1 foot = 0.3048 meter).
3D products
On the 3D Products tab, these options allow you to change the outputs for the point cloud and 3D textured mesh created in this step.
  • Create 3D Point Clouds—Allows you to select the output formats for the point cloud. The options are as follows:
  • Create DSM Textured Meshes—Allows you to generate 3D meshes from DSM data with an imagery overlay.
    • OBJ—Converts DSM data into a Wavefront (.obj) file.
    • OSGB—Converts DSM data into an OpenSceneGraph binary (.osgb) file.
    • 3D Tiles—Converts point cloud data into 3D Tiles (.b3dm) files.
    • Export OBJ in Project Coordinates—Set the .obj file vertices to be written using the project coordinate system. Use this option if the file will be opened in viewers that support spatial reference systems.
  • Create 3D Textured Meshes—Allows you to generate 3D meshes from point cloud data with an imagery overlay.
    The densified point cloud is used to generate a surface composed of triangles. It uses the points to minimize the distance between the points and the surface that they define, but the vertices of the triangles are not necessarily an exact point of the densified point cloud.
    • OBJ—Converts point cloud data into a Wavefront (.obj) file.
    • OSGB—Converts point cloud data into an OpenSceneGraph binary (.osgb) file.
  • Create Gaussian Splats—Allows you to enable the generation of a Gaussian splat layer.
    • 3D Tiles—Creates a Gaussian splat layer as a 3D Tiles (.b3dm) file and as a .json file.
      Generating a Gaussian splat layer requires a separate deep learning package installation. See Optional installation packages.
      Additionally, the processing of Gaussian splat layers is hardware intensive with specific GPU requirements. See ArcGIS Drone2Map system requirements.
Coordinate systems
On the Coordinate systems tab, the following options define the horizontal and vertical coordinate system for your images and the project.
  • Image Coordinate System—Defines the spatial reference for your images.
    • Current XY—Defines the horizontal coordinate system for your images. The default horizontal coordinate system for images is WGS84. To update the image horizontal coordinate system, click the coordinate system button to select the appropriate coordinate system, and click OK.
    • Current Z—Defines the vertical reference for your images. The default vertical reference is EGM96 for images. Most image heights are referenced to the EGM96 geoid and are either embedded in the EXIF header of the image or are contained in a separate file. Most GPS receivers convert the WGS84 ellipsoidal heights provided by global navigation satellites to EGM96 heights, so if you're unsure, accept the default of EGM96.
  • Control Coordinate System—Displays the spatial reference for your control points.
    Control coordinate systems are defined when importing ground control points and this information will only appear if control is present within a project.
    • Current XY—The horizontal coordinate system being used for your control points.
    • Current Z—The vertical reference being used for your control points.
  • Project Coordinate System—Defines an output spatial reference for your Drone2Map output products.
    If you have control points, the project coordinate system and vertical reference of Drone2Map are determined by the coordinate system and vertical reference of the control points. When using a geographic coordinate system for control, Drone2Map defaults to the nearest UTM Zone.
    If you don’t have control points, the coordinate system and vertical reference model used in the creation of Drone2Map are determined by the coordinate system and vertical reference of the images themselves.
    Coordinate systems can only be modified before the camera model has been computed.
    • Current XY—Defines the output horizontal coordinate system. To update the project coordinate system, click the Set Horizontal and Vertical Spatial Reference button to select the appropriate projected coordinate system, and click OK. If you select a geographic coordinate system, Drone2Map generates products using the local WGS84 UTM zone.
    • Current Z—Defines the output vertical reference system for your Drone2Map products. This is relevant if your input images contain ellipsoidal heights and you plan to publish a 3D mesh as a scene layer, since ArcGIS Online and ArcGIS Pro both use the orthometric EGM96 geoid height model. EGM96 is the default.
  • Coordinate System Transformation—Defines a transformation to be used for converting between different image and project horizontal and vertical coordinate systems.
Project Data
The Project Data tab allows you to quickly reset various project processing steps and options. It also allows you to delete specific layers and products.
  • Reset Options—Reset processing options to the original state at project creation.
    • Toggle All Entries Accept All Entries—Turns on or off all options in the section.
    • 2D Products—Resets all processing options on the 2D Products tab to the template defaults.
    • 3D Products—Resets all processing options on the 3D Products tab to the template defaults.
    • Adjust Images—Resets all processing options on the Adjust Images tab to the template defaults.
    • General—Resets all processing options on the General tab to the template defaults.
  • Reset Processing Steps—Turns on options to reset processing steps to an unprocessed state. Processing steps that depend on another processing step are reset together.
    • Image collection—Resets all processing steps for Image collection .
    • Adjust Images—Resets all processing steps for Adjust Images.
    • Product Generation—Resets all processing steps for Product Generation.
  • Reset Symbology—Turns on options to reset project layers to their original symbology.
    • 2D Products—Resets the symbology for all 2D Products.
    • 3D Products—Resets the symbology for all 3D Products.
    • Clip Area—Resets the symbology for the Clip Area feature layer.
    • Control—Resets the symbology for the Control feature layer.
    • Flight Data—Resets the symbology for the Flight Data feature layer.
    • Inspection—Resets the symbology for the Inspection feature layer.
    • Map Notes—Resets the symbology for the Map Notes feature layers.
    • Pre-Processing—Resets the symbology for any of the Pre-Processing feature layers.
  • Delete Project Data—Turns on options to delete data from the project and file system.
    • 2D Products—Deletes all 2D output products from the project.
    • 3D Products—Deletes all 3D output products from the project.
    • Contours—Deletes all Contour products from the project.
    • Control—Deletes the Control feature layer from the project and imported ground control points.
    • Elevation Profiles—Deletes the Elevation Profile data and charts from the project.
    • Map Notes—Deletes the Map Notes data from the project.
    • Measurements—Deletes all measurement feature layers from the project.
    • Pre-Processing—Deletes all Pre-Processing data from the project.
    • Processing Report—Deletes the Processing Report data from the project.
    • Shaded Relief—Deletes all Shaded Relief products from the project.
  • Restore Backup Products—Restore products to their original state. If more than one backup exists, the original product for the project will be restored.
    • 2D Products—Restores original 2D product for the project.
    • 3D Products—Restores original 3D product for the project.
  • Reset Map Data—Resets data on the map to its original processed state.
    • Elevation Surface—Resets the map elevation surface data layers to their original state.
  • Project logs—Delete project logs for the current project.
    • Delete logs—Deletes logs.
Export template
Drone2Map templates are designed to help you get your projects started quickly. The templates are preconfigured with specific processing options based on the template and desired products. You can update the processing options to customize processing settings and outputs. If you have a particular set of custom options that you use frequently, you can export your processing options as a template. Once your processing options are set, in the Options window, select Export Template, browse to the location where you want to save your template, and click Save. When you create your next project, choose your exported template, and your settings and options are loaded into Drone2Map.
Coordinate system information is not included with the exported template.
