Upgrade a primary-standby ArcGIS Data Store deployment using CloudFormation
The Esri arcgis-datastore-primarystandby-upgrade.template.json Amazon Web Services (AWS) CloudFormation template upgrades the following on two Amazon Elastic Compute Cloud (EC2) instances (primary and standby) that you created using the template described in Deploy ArcGIS Data Store in primary-standby mode using CloudFormation:
An ArcGIS Data Store 11.0, 11.1, 11.2, 11.3, 11.4, 11.5, or 12.0 relational store
An ArcGIS Data Store 11.2, 11.3, or 11.4 graph store
Primary-standby mode is no longer supported for the graph store. If you upgrade from 11.4 or earlier, the graph store will be running in single instance mode and will contain only one EC2 instance.
If you require high availability after upgrading from 11.4 or earlier, you can change the graph store deployment mode to cluster and add two EC2 instances configured as graph store machines. However, you must use the ArcGIS Data Store
configuredatastoreutility to change the graph store to cluster mode, install the ArcGIS Data Store graph store on two new EC2 instances, and run the theconfiguredatastoreutility on each of those instances to configure each graph store machine with the same hosting server. Going forward, you must use the manual procedure for subsequent upgrades.
The tile cache data store is no longer supported. You cannot upgrade to 12.1 if the ArcGIS Enterprise deployment includes a tile cache data store that still contains scene layer caches. You must first upgrade to 11.5, add an object store, and migrate existing hosted scene layer caches to the object store. Then you can upgrade from 11.5 to 12.1. Refer to the ArcGIS Enterprise 11.5 documentation for upgrade and migration instructions.
The arcgis-datastore-primarystandby-upgrade.template.json template upgrades ArcGIS Data Store on two EC2 instances.
Prerequisites
Prerequisites can be grouped by the items—such as files and accounts—that you must obtain and the tasks you must perform before running the CloudFormation template.
Required items
You need the following before running this template:
An Amazon Web Services account with access to the deployment to be upgraded
An existing primary-standby ArcGIS Data Store deployment that you created using the Esri Amazon Web Services CloudFormation template
arcgis-datastore-primarystandby.template.json.The upgrade CloudFormation template,
arcgis-datastore-primarystandby-upgrade.template.json.
To upgrade the deployment, run this upgrade CloudFormation template, which will create a new CloudFormationstack. Do not update the existing deployment CloudFormation stack using this template.
Required tasks
Complete the following tasks before running this template:
You must upgrade the ArcGIS GIS Server site (hosting server) that this data store is registered with before you upgrade ArcGIS Data Store.
Configure passwords in AWS Secrets Manager (optional but recommended).
You can configure the passwords for accounts such as the site administrator username and the Windows ArcGIS user account's password in AWS Secrets Manager. This provides you with a secret Amazon Resource Name (ARN). Use the ARN in place of a password in the template parameters when you launch a stack. If you don't use AWS Secrets Manager for storing passwords, you must type passwords in plain text in the template parameter when launching the stack.
When creating a secret ARN in AWS Secrets Manager for a password to be used with Esri CloudFormation templates, you must use the Other types of secrets secret type and use the Plaintext option. For more information about creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS.
Tip:
By default, CloudFormation deletes partially created resources if stack creation fails. This is helpful because it removes unusable deployments from your account, but it can make it difficult to troubleshoot. To retain the stack in its failed state, disable the Rollback on failure CloudFormation stack creation option before launching the stack. See Setting AWS CloudFormation options in the AWS help for more information.
Parameters
Refer to the following tables for descriptions of the parameters used in this CloudFormation template. Tables are grouped by parameter type.
ArcGIS Data Store Configuration
Parameter name |
Required or not |
Parameter description |
Platform Type |
Required |
Choose the platform type of your existing ArcGIS Data Store deployment.
Primary ArcGIS Data Store EC2 Instance ID |
Required |
Choose the ID of the primary EC2 instance in your existing ArcGIS Data Store deployment. If you created the existing deployment using an Esri CloudFormation template or Cloud Builder, you can find the instance ID in the existing CloudFormation stack's Resources section in AWS Management Console. The logical ID of the resource is ArcGIS DatastorePrimaryEC2Instance. |
Standby ArcGIS Data Store EC2 Instance ID |
Required |
Choose the ID of the standby EC2 instance in your existing ArcGIS Data Store deployment. If you created the existing deployment using an Esri CloudFormation template or Cloud Builder, you can find the instance ID in the existing CloudFormation stack's Resources section in AWS Management Console. The logical ID of the resource is ArcGIS DatastoreStandbyEC2Instance. |
Type |
Required |
Choose the data store type of your existing ArcGIS Data Store deployment. Valid values are relational or graph. The graph value is only valid if you're upgrading from 11.2, 11.3, or 11.4. |
ArcGIS User Account Name |
Optional |
Provide the username of the local login that runs the ArcGIS software. You specified this name when you created the deployment. If you did not specify a name, the login name is arcgis. |
Windows arcgis user password |
Conditional |
This password is only required if you deployed on Windows. Provide the password for the arcgis user of your existing deployment. You can either enter a plain text password or the ARN of your secret ID from AWS Secrets Manager. It's a best practice to manage your passwords in AWS Secrets Manager. For information on creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS. |
ArcGIS Server Configuration
Parameter name |
Required or not |
Site Administrator User Name |
Required |
Provide the username for the ArcGIS Server primary site administrator of your existing site. |
Site Administrator User Password |
Required |
Provide a password for the ArcGIS Server primary site administrator. You can either type a plain text password or the ARN of your secret ID from AWS Secrets Manager. For more information on creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS. The password or secret ID you provide must match that of the existing primary site administrator. |
ArcGIS Server EC2 Instance ID |
Required |
Choose an EC2 instance ID from the ArcGIS Server site with which the data store is configured. Note:If the data store is registered with a multimachine ArcGIS Server site, you can choose any EC2 instance ID from the ArcGIS Server site. Do not choose a file server EC2 instance. |
Outputs
When your stack is created successfully, you can see the following output parameters on the Outputs tab of the CloudFormation stack in AWS Management Console.
Output name |
Output description |
DeploymentLogsURL |
This is the URL for the Amazon CloudWatch logs where all deployment logs are stored. You can refer to these logs for troubleshooting purposes if your deployment fails. |
Considerations
Consider the following when creating a CloudFormation stack containing ArcGIS deployments:
Once the stack is created successfully (the stack status is CREATE_COMPLETE), that means the ArcGIS Data Store deployment is upgraded successfully. You can confirm this by signing in to ArcGIS Server Manager and validating the data store.
If the CloudFormation stack failed to create successfully (the stack status is CREATE_FAILED), you can troubleshoot the error as mentioned in the page linked to from the Troubleshooting section below. After determining the root cause of the error and taking required action, you can delete the failed stack and create a new one to upgrade the existing ArcGIS Data Store deployment.
Troubleshooting
If you observe any failures when creating this CloudFormation stack, see Troubleshoot ArcGIS deployments on AWS.
