Upgrade ArcGIS Enterprise on one machine using CloudFormation
The Esri arcgis-enterprise-allinone-upgrade.template.json Amazon Web Services (AWS) CloudFormation template upgrades an ArcGIS Enterprise 11.0, 11.1, 11.2, 11.3, 11.4, 11.5, or 12.0 deployment on one Amazon Elastic Compute Cloud (EC2) instance plus one EC2 instance for a file server that was created using the template described in Deploy ArcGIS Enterprise on one machine using CloudFormation.
The arcgis-enterprise-allinone-upgrade.template.json template upgrades the following components on a single machine on AWS:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Web Adaptor
  • ArcGIS Data Store
The tile cache data store is no longer supported. You cannot upgrade to 12.1 if the ArcGIS Enterprise deployment includes a tile cache data store that still contains scene layer caches. You must first upgrade to 11.5, add an object store, and migrate existing hosted scene layer caches to the object store. Then you can upgrade from 11.5 to 12.1. Refer to the ArcGIS Enterprise 11.5 documentation for upgrade and migration instructions.
Prerequisites
Prerequisites can be grouped by the items—such as files and accounts—that you must obtain and the tasks you must perform before running the CloudFormation template.
Required items
You need the following before running this template:
  • An Amazon Web Services account with access to the deployment to be upgraded
  • Esri license files for Portal for ArcGIS, ArcGIS GIS Server, and any ArcGIS Server licensing roles. All license files must be for the same ArcGIS version.
  • An SSL certificate file or certificates (a .pfx file) and corresponding passwords. Certificates must be from a certifying authority.
  • An existing ArcGIS Enterprise deployment that you created using the Esri Amazon Web Services CloudFormation template arcgis-enterprise-allinone.template.json.
  • The upgrade CloudFormation template, arcgis-enterprise-allinone-upgrade.template.json.
To upgrade the deployment, run this upgrade CloudFormation template, which will create a new CloudFormationstack. Do not update the existing deployment CloudFormation stack using this template.
Required tasks
Complete the following tasks before running this template:
  • Prepare a deployment Amazon Simple Storage Service (S3) bucket in your AWS account. Specify the bucket name in the template when you launch the stack.
    1. Create a bucket or use an existing S3 bucket. You must be the owner of the bucket.
    2. Upload the ArcGIS software authorization files to the bucket.
    3. Upload your SSL certificate file to the deployment bucket.
  • Configure passwords in AWS Secrets Manager (optional but recommended).
    You can configure the passwords for accounts such as the site administrator username and the Windows ArcGIS user account's password in AWS Secrets Manager. This provides you with a secret Amazon Resource Name (ARN). Use the ARN in place of a password in the template parameters when you launch a stack. If you don't use AWS Secrets Manager for storing passwords, you must type passwords in plain text in the template parameter when launching the stack.
    When creating a secret ARN in AWS Secrets Manager for a password to be used with Esri CloudFormation templates, you must use the Other types of secrets secret type and use the Plaintext option. For more information about creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS.
Tip:
By default, CloudFormation deletes partially created resources if stack creation fails. This is helpful because it removes unusable deployments from your account, but it can make it difficult to troubleshoot. To retain the stack in its failed state, disable the Rollback on failure CloudFormation stack creation option before launching the stack. See Setting AWS CloudFormation options in the AWS help for more information.
Parameters
The following table contains the parameters used in this template and a description of each parameter.
ArcGIS Enterprise Configuration
Parameter name
Required or not
Parameter description
Platform Type
Required
Choose the platform type of your existing ArcGIS Enterprise deployment.
  • Windows
  • Linux
ArcGIS Enterprise EC2 Instance ID
Required
Choose the ID of the EC2 instance in your existing ArcGIS Enterprise deployment.
If you created the existing deployment using an Esri CloudFormation template or ArcGIS Enterprise Cloud Builder for AWS, you can find the instance ID in the existing CloudFormation stack's Resources section in AWS Management Console. The logical ID of the resource is AllInOneEC2Instance.
Deployment Bucket Name
Required
Provide the name of the Amazon S3 bucket that contains your software license files and SSL certificates. This bucket must already exist and contain the license file and SSL certificate for your deployment.
You must be the owner of the bucket and it must reside in the same AWS account as your deployment.
Portal License File Name
Required
Provide the Portal for ArcGIS authorization file object key name. You must upload the license file (.json file) to the deployment bucket before launching this stack. You can get the file object key name by browsing to the file in the deployment bucket in the AWS S3 console, for example, portal.json or resources/licenses/portal/portal.json.
License file names are case sensitive. Ensure that you type the correct name and case.
Server License File Name
Required
Provide the ArcGIS Server authorization file object key name. You must upload the license file (.ecp or .prvc) to the deployment bucket before launching this stack.
To get the file object key name, browse to the file in the deployment bucket in the Amazon S3 console, for example, server.prvc or resources/licenses/server/server.prvc.
You must use an ArcGIS GIS Server license because it will be used to license the hosting server.
License file names are case sensitive. Ensure that you type the name correctly.
Portal and Server Administrator User Name
Required
Provide a username for the initial portal administrator and the ArcGIS Server primary site administrator of your existing deployment.
Portal and Server Administrator User Password
Required
Provide a password for the initial portal administrator and the ArcGIS Server primary site administrator of your existing deployment.
You can either type a plain text password or the ARN of your secret ID from AWS Secrets Manager.
ArcGIS User Account Name
Optional
Provide the username of the local login that runs the ArcGIS software.
You specified this name when you created the deployment. If you did not specify a name, the login name is arcgis.
Windows arcgis user password
Conditional
This password is only required if you deployed on Windows. Provide the password for the arcgis user of your existing deployment.
You can either enter a plain text password or the ARN of your secret ID from AWS Secrets Manager.
It's a best practice to manage your passwords in AWS Secrets Manager. For information on creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS.
Domain Name
Required
Provide the fully qualified domain name of your existing ArcGIS Enterprise deployment.
Portal Web Adaptor Name
Required
Provide the Portal for ArcGIS web adaptor name of your existing ArcGIS Enterprise deployment.
Server Web Adaptor Name
Required
Provide the ArcGIS Server web adaptor name of your existing ArcGIS Enterprise deployment.
SSL Certificate File Name
Required
Provide an SSL certificate from a certifying authority (.pfx file). Use the same (or renewed) SSL certificate used when you created your existing deployment.
You must upload the certificate to the deployment bucket before launching this stack. You can get the file object key name by browsing to the file in the deployment bucket in the AWS S3 console, for example, domainname.pfx or resources/sslcerts/domainname.pfx.
SSL Certificate Password
Required
Provide the password for the SSL certificate. You can either type a plain text password or the ARN of your secret ID from AWS Secrets Manager. For information on creating an Amazon Resource Name for passwords, see AWS CloudFormation and ArcGIS.
Outputs
When your stack is created successfully, you can see the following output parameters on the Outputs tab of the CloudFormation stack in AWS Management Console.
Output name
Output description
PortalHomeAppURL
The URL to access the portal.
ServerManagerDirURL
The ArcGIS Server Manager URL.
ServerRestDirURL
The ArcGIS Server REST Services URL.
DeploymentLogsURL
This is the URL for the Amazon CloudWatch logs where all deployment logs are stored. You can refer to these logs for troubleshooting purposes if your deployment fails.
Considerations
Consider the following when creating a CloudFormation stack containing ArcGIS deployments:
  • Once the stack is created successfully (the stack status is CREATE_COMPLETE), that means the ArcGIS Enterprise deployment is upgraded successfully. You can validate this by signing in to the portal website, ArcGIS Server Manager for the hosting server, or the REST services directory.
  • If the CloudFormation stack failed to create successfully (the stack status is CREATE_FAILED), you can troubleshoot the error as mentioned in the page linked to from the Troubleshooting section below. After determining the root cause of the error and taking required action, you can delete the failed stack and create a new one to upgrade the existing ArcGIS Enterprise deployment.
  • If you receive a notice regarding licenses when you sign in to the portal after an upgrade, you may not have imported a license file that meets your current licensing configuration, or your users may be assigned a temporary user type. See Considerations after upgrading Portal for ArcGIS in the Portal for ArcGIS installation guide.
Troubleshooting
If you observe any failures when creating this CloudFormation stack, see Troubleshoot ArcGIS deployments on AWS.
