Operating systems supported when using ArcGIS Enterprise tools for AWS
When you use an ArcGIS Enterprise tools for Amazon Web Services (AWS), you can specify a base Amazon Machine Image (AMI) ID to use for the Amazon Elastic Compute Cloud (EC2) instances included in your deployment. The AMI ID you specify must use a supported operating system version. These versions are listed in the following sections.
Linux
The following Linux operating systems are supported for all ArcGIS Enterprise 12.2:
  • Ubuntu Server 24.04 LTS
  • Ubuntu Server 22.04 LTS
  • Red Hat Enterprise Linux Server 9
  • SUSE Linux Enterprise Server 15
  • AlmaLinux 9
  • Oracle Linux 9
  • Rocky Linux 9
Always confirm that Docker is configured on the machine before you configure ArcGIS Notebook Server. See the ArcGIS Notebook Server Linux installation guide for instructions.
Microsoft Windows
The following Windows operating system versions are supported when you create a 12.2 or ArcGIS Pro 3.8 deployment using an ArcGIS Enterprise on AWS tool:
  • Windows Server 2025 Standard and Datacenter
  • Windows Server 2022 Standard and Datacenter
  • Windows Server 2019 Standard and Datacenter
  • Windows 11 Pro and Enterprise
For ArcGIS Enterprise, Windows 11 is supported for basic testing and application development use only. It is not recommended for deployment in a production environment. If you deploy ArcGIS Pro on its own EC2 instance, Windows 11 is supported for production environments.
ArcGIS Notebook Server is not supported on Windows operating systems when you deploy the site using an Esri CloudFormation template or Cloud Builder for AWS.
