ArcGIS Enterprise tools for Amazon Web Services
ArcGIS Enterprise on Amazon Web Services (AWS) tools help you deploy the components of ArcGIS Enterprise on AWS. They can be used to create any of the following:
Available tools
The following tools are available:
AWS CloudFormation templates
Esri provides sample CloudFormation templates that you can alter and run to create and upgrade ArcGIS deployments on AWS.
You can use these templates in the AWS Management Console or use Python or Windows PowerShell tools to automate creation of these same architectures.
ArcGIS Enterprise Cloud Builder for AWS
ArcGIS Enterprise Cloud Builder for Amazon Web Services includes the ArcGIS Enterprise Cloud Builder Command Line Interface for Amazon Web Services and the ArcGIS Enterprise Cloud Builder for Amazon Web Services app.
The command line interface uses JSON files containing parameters that you alter to meet your needs, is built on the Esri templates, and provides a way to automate deployment creation. The PREP command automates preparatory steps and the CREATE command deploys ArcGIS.
The ArcGIS Enterprise Cloud Builder for Amazon Web Services app provides a graphical user interface (GUI) that guides you through options to provision resources and create ArcGIS deployments. The app uses the same JSON files and Esri AWS CloudFormation templates as ArcGIS Enterprise Cloud Builder CLI for AWS, but the app populates these files for you.
Security resources
The ArcGIS Enterprise tools for AWS configure the following security resources for you:
Windows Firewall
Microsoft Windows Firewall is enabled and configured when you use ArcGIS Enterprise tools for AWS. All ports that are necessary for ArcGIS Enterprise components to run are open to inbound connections.
Outbound connections are allowed by default in the Windows Firewall on the Amazon Elastic Compute Cloud (EC2) instances you create using ArcGIS Enterprise tools for Amazon Web Services.
Security groups
When you use ArcGIS Enterprise tools for Amazon Web Services, a security group is created for you, and HTTPS and HTTP access is granted. However, if you intend to work with your EC2 instances using a Remote Desktop Connection or SSH, you must add rules allowing those types of connections. See the AWS documentation for instructions to alter security groups.
IAM policies
For information about what IAM policies are set by the tools, see IAM policies created by ArcGIS Enterprise tools for AWS.
Supported operating systems
In some cases, the ArcGIS Enterprise tools for AWS support different operating systems than on-premises deployments. See Operating systems supported when using ArcGIS Enterprise tools for AWS for information.
Supported AWS regions
Each release of the ArcGIS Enterprise tools for AWS supports different AWS regions.
For a list of the AWS regions currently supported for each active ArcGIS release, see FAQ: What AWS regions are supported for every active ArcGIS release on the Esri Technical Support site.
