Upgrade an ArcGIS Server site on AWS
This information applies to upgrading a stand-alone ArcGIS Server site or a federated ArcGIS Server site that is configured on an Amazon Elastic Compute Cloud (EC2) instance or instances separate from other ArcGIS Enterprise components.
How you upgrade depends on how and when you created the ArcGIS Server site on Amazon Web Services (AWS). This includes ArcGIS GIS Server, ArcGIS Image Server, or ArcGIS Knowledge Server sites.
To determine what method to use to upgrade, see ArcGIS upgrades on Amazon Web Services ArcGIS upgrades on Amazon Web Services.
Before you upgrade
Regardless of the upgrade method you use, review the following information before you upgrade the deployment:
Read ArcGIS upgrades on Amazon Web Services to determine what method to use to upgrade and discover whether you must perform extra tasks before upgrading to 12.1. Complete all required tasks before upgrading.
You must obtain a new license file to upgrade.
Make a backup of the ArcGIS Server site before upgrading.
If the ArcGIS Server site is federated, you must upgrade the Portal for ArcGIS component before upgrading this federated server.
If you use manual procedures or a Chef script to upgrade, you must remove the Amazon Elastic Compute Cloud (EC2) instances in the ArcGIS Server site from the AWS Auto Scaling group (if it is in one) before you can upgrade the site. Once upgraded, you cannot put the instances back in the Auto Scaling group. Therefore, you must manually add instances to or delete instances from the ArcGIS Server site when needed, and you cannot use the Lambda functions created using Amazon Web Services CloudFormation templates provided by Esri to stop and start these instances.
If you don't remove the instances or if you put the instances back in the Auto Scaling group after you upgrade, instances added to the ArcGIS Server site by the Auto Scaling group will be running the old version of the software. You cannot have a mix of ArcGIS Server versions in a site, so this can corrupt your deployment.
Upgrade using manual upgrade procedures
The manual upgrade procedure for an ArcGIS Server site on AWS is similar to upgrading one on-premises. The difference on AWS is that, if the ArcGIS Server site Amazon Elastic Compute Cloud instances are deployed in an AWS Auto Scaling group, you must remove them from the Auto Scaling group before you upgrade.
If the starting version or components in your deployment require you to upgrade to an interim version, follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Follow these steps to remove all EC2 instances from the Auto Scaling group.
Sign in to AWS Management Console and find the Auto Scaling group associated with your ArcGIS Server site.
The Auto Scaling group includes the name of the CloudFormation stack. You can also open instance management for the group and confirm the EC2 instances in the group participate in your site.
Change the minimum capacity and maximum capacity properties of the stack's Auto Scaling group to 0.
Remove all the EC2 instances from the Auto Scaling group.
Change the desired capacity property of the Auto Scaling group to 0.
Once you remove all EC2 instances, delete the Auto Scaling group to prevent anyone from adding the instances back after the ArcGIS Server site is upgraded.
Now you can follow instructions to upgrade the ArcGIS Server site. Read the instructions specific to the operating system on your EC2 instances:
Upgrade using Chef scripts
If you created the ArcGIS Server site using a 10.8 or 10.8.1 Esri Amazon Web Services CloudFormation template, you can upgrade using Chef scripts.
As indicated in ArcGIS upgrades on Amazon Web Services, if the deployment is still at version 10.8, 10.8.1, 10.9, or 10.9.1 or if the deployment includes components that are no longer supported, you must first upgrade to an interim version before upgrading to 12.1. Follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Upgrade steps are different for deployments on Microsoft Windows and Ubuntu. Follow the instructions applicable to the operating system of your deployment.
Upgrade a site on Windows
Follow these steps to use Chef to upgrade an ArcGIS Server site on Windows Amazon EC2 instances.
Adjust the Auto Scaling group settings
Sign in to AWS Management Console and find the Auto Scaling group associated with the ArcGIS Server site.
Download the Chef client and ArcGIS Server to all EC2 instances and upgrade
Sign in to each of the EC2 instances in the ArcGIS Server site to install the Chef client, install the latest version of ArcGIS Server, and upgrade.
Make a remote desktop connection to the first EC2 instance in the ArcGIS Server site.
Download and install a supported Chef or Cinc client.
See the ArcGIS Cookbook compatibility matrix for supported versions.
Download the following ArcGIS Server 12.1 installation files from your account in My Esri and upload the files to a folder on the EC2 instance.
ArcGIS_Server_Windows_121_200157.exeArcGIS_Server_Windows_121_200157.exe.001
Obtain an ArcGIS GIS Server or ArcGIS Image Server 12.0 authorization file and place it in a local folder on the EC2 instance or a file share that you can access from the EC2 instance.
Download the ArcGIS Cookbook version 5.4.0 (
arcgis-5.4.0-cookbooks.zip) to the EC2 instance, unzip the file, and place the contents of the unzipped file in theC:\cheffolder.Delete the
C:\chef\nodesfolder.Create a copy of your original
C:\chef\node.jsonfile and rename it toupgrade_server_windows.json.Open the
upgrade_server_windows.jsonfile in a text editor.Set the ArcGIS version to 12.1.
"arcgis" : { "version": "12.1",Specify the location where you placed the ArcGIS Server authorization file.
"arcgis" : { "server": { "authorization_file" : "<drive>\\<folder>"Set the ArcGIS archive repository to the folder where you placed the software file on the EC2 instance.
"arcgis" : { "repository": { "archives": "<drive>\\<folder>"Modify the run list to use the following recipe only:
"recipe[arcgis-enterprise::server]"
Save and close the
upgrade-server_windows.jsonfile.Open a command line window as an administrator, change the directory to
C:\chef, and run the following command:chef-client -z -j c:\chef\upgrade-server_windows.json.If there is more than one EC2 instance in the ArcGIS Server site, make a remote desktop connection to the next EC2 instance and repeat steps 2 through 11 until all instances are upgraded.
Upgrade a site on Ubuntu
Follow these steps to use Chef to upgrade an ArcGIS Server site on Ubuntu Amazon EC2 instances.
As the ubuntu user, make an SSH connection to the first EC2 instance in the ArcGIS Server site.
Use one of the following commands to download and install a supported Chef or Cinc client.
See the ArcGIS Cookbook compatibility matrix for supported versions. Replace the version number text in the following statements with the client version you install.
Chef client:
sudo curl -L https://omnitruck.chef.io/install.sh | sudo bash -s -- -v <version_number>Cinc client:
sudo curl -L https://omnitruck.cinc.sh/install.sh | sudo bash -s -- -v <version_number>
Download the ArcGIS Server installation file (
ArcGIS_Server_Linux_121_200205.tar.gz) from your account in My Esri and upload the files to a folder on the EC2 instance.Obtain an ArcGIS GIS Server or ArcGIS Image Server authorization file and place it in a local folder on the EC2 instance or a file share that you can access from the EC2 instance.
arcgis-5.4.0-cookbooks.tar.gz) to the EC2 instance, untar and unzip the file, and place the files contents in the/var/chefdirectory.Create a copy of your original
/etc/chef/node.jsonfile and rename it toupgrade_server_linux.json.Open the
upgrade_server_linux.jsonfile in a text editor.Set the ArcGIS version to 12.1.
"arcgis" : { "server": { "authorization_file" : "/<folder>/<subfolder>"Set the ArcGIS archive repository to the folder where you placed the software file on the EC2 instance.
"arcgis" : { "repository": { "archives": "/<folder>/<subfolder>"Modify the run list to use the following recipe only:
Save and close the
upgrade-server_windows.jsonfile.As the ubuntu user, change the directory to
/var/chef, and run the following command:chef-client -z -j /etc/chef/upgrade-server_linuxs.json.If there is more than one EC2 instance in the ArcGIS Server site, make an SSH connection to the next EC2 instance and repeat steps 2 through 9 until all instances are upgraded.
Upgrade using a CloudFormation template
If you used a 10.9 or later CloudFormation template provided by Esri to create an ArcGIS Server site, you can use the corresponding 12.1 upgrade template to upgrade to 12.1.
The following table lists corresponding deployment and upgrade templates and provides links to instructions for using the upgrade templates:
Deployment template |
Upgrade template |
Instructions to use upgrade template |
Upgrade a single-machine ArcGIS Server site using CloudFormation |
Upgrade a highly available ArcGIS Server site using CloudFormation |
