Upgrade an ArcGIS Workflow Manager site on AWS
This information applies to upgrading an ArcGIS Workflow Manager site configured on an Amazon Elastic Compute Cloud (EC2) instance or instances separate from other ArcGIS Enterprise components.
How you upgrade depends on how you created the ArcGIS Workflow Manager site on Amazon Web Services (AWS).
Before you upgrade
Regardless of the upgrade method you use, review the following information before you upgrade the deployment:
  • Read ArcGIS upgrades on Amazon Web Services to determine if your deployment requires that you perform extra tasks before upgrading to 12.1. Complete all required tasks before upgrading.
  • You must obtain a new license file to upgrade.
  • Make a backup of the ArcGIS Workflow Manager site before upgrading.
  • You must upgrade the portal component with which ArcGIS Workflow Manager is federated before upgrading the ArcGIS Workflow Manager site.
Upgrade using manual upgrade procedures
The manual upgrade procedure for an ArcGIS Workflow Manager site on AWS is similar to upgrading one on-premises. Therefore, follow instructions in Upgrade ArcGIS Workflow Manager to upgrade the site. Read the instructions specific to the operating system on your EC2 instances.
Upgrade using a CloudFormation template
If you used an 11.1 or later CloudFormation template provided by Esri to create an ArcGIS Workflow Manager site, you can use the corresponding 12.1 upgrade template to upgrade to 12.1.
The following table lists corresponding deployment and upgrade templates and provides links to instructions for using the upgrade templates.
Deployment template
Upgrade template
Instructions to use upgrade template
arcgis-workflow-manager-singlemachine.template.json
arcgis-worklfow-manager-singlemachine-upgrade.template.json
Upgrade a single machine ArcGIS Workflow Manager site using CloudFormation
arcgis-workflow-manager-ha.template.json
arcgis-worklfow-manager-ha-upgrade.template.json
Upgrade a multiple machine ArcGIS Workflow Manager site using CloudFormation
