Create a backup
After registering a staging location and a backup store, you can create backups using ArcGIS Enterprise Manager. It is recommended that you create backups during downtime to ensure that the additional requests for resources do not cause issues for users accessing the deployment.
Create a backup using ArcGIS Enterprise Manager
To create a backup, complete the following steps:
  1. Sign in to ArcGIS Enterprise Manager as an administrator of your organization.
  2. Click the Backups button.
  3. On the backups page, click Create new and provide the following information:
    1. Set a backup name—The name of the backup.
    2. Choose a backup store—The backup store where the backup will be stored.
    3. Set an encryption passphrase and Confirm encryption passphrase—The passphrase that is used to encrypt the backup.
      The backup cannot be restored without the passphrase.
    4. Show encryption passphrase—The passphrase in plain text for verification.
    5. Automatically delete backups—The backup retention policy. This is enabled by default with a 14-day retention period. You can select the date the backup expires or the number of days, weeks, or months the backup is retained, or disable the option and permanently retain the backup.
  4. Click Create.
When the backup operation begins, a job and an additional pod start and coordinate the backup process. The amount of time it takes to create the backup is based on the number of items in the deployment. The following table summarizes the possible result states of a completed backup operation.
Result state
Meaning
success
No action necessary, all configuration and data backup stages completed successfully.
success_with_warnings
Objects failed to mirror, compromising the integrity of the backup. An administrator should review the logs and messages to determine the areas of potential impact. If this condition persists across multiple backup attempts, contact Esri Technical Support.
failure
One or more backup stages failed to persist the information to the backup store. An administrator should review the logs and messages to determine cause of the failure and correct before creating a new backup, then this backup can be deleted. If this condition persists across multiple backups attempts, contact Esri Technical Support.
By default, backup operations that take longer than two hours to complete are automatically canceled. If a deployment contains a large amount of data and takes longer than two hours to back up, you can change the backup operation's time-out value in the Disaster Recovery settings.
Change the time-out value
To change the time-out value, complete the following steps:
  1. Sign in to ArcGIS Enterprise Administrator API as an administrator of your organization.
  2. Click System > Disaster Recovery > Settings.
  3. Click Update Settings.
  4. Update the JSON in the Settings text box to include the timeoutInMinutes property.
        "timeoutInMinutes": 10800,
        "stagingVolumeConfig": {
            "provisioningType":"DYNAMIC",
            "storageClass": "staging",
            "size": "64Gi"
Check the status of a backup
After clicking Create in the Create new window, the backup status page will automatically appear. If you leave the page and want to recheck the status of an ongoing backup process, do the following:
  3. On the backups page, locate the ongoing backup process and click the Completed link.
Schedule backups
To minimize data loss in the event of a failure, schedule backups at regular intervals. Once a schedule is configured, backups are created automatically at a fixed time in the future, either once or on a recurring basis. You can restore any of the backups to recover the organization to the point in time when the backup was created. The backup schedule should be determined by the recovery point objective (RPO) of your organization.
To schedule backups, complete the following steps:
  3. On the backups page, click Scheduled backups.
  4. Click New schedule and provide the following information:
    1. Set a backup name—The prefix that is used to name the backup. The date and time the backup is created is added to the name as a suffix. For example, if the prefix is enterprise-backup, the date and time the backup is created is appended to it to form the backup name of enterprise-backup-2021-09-02-18-08-17.
    5. Beginning date and Time—The date and time the backup will occur.
    6. Make recurring—Set the backup process to recur.
    7. Repeat every—How often backups are created. Each backup process starts from the specified Beginning date and Time value.
      • Hour—Create a backup based on the specified hour. For example, create a backup every hour.
      • Day—Create a backup based on the specified day. For example, create a backup every day at 12:00 a.m..
      • Week—Create a backup based on the specified day of the week. For example, create a backup at 12:00 a.m. on Saturday.
    8. End—When the schedule ends. You can make it an indefinite schedule that does not have an end date or count, a schedule that ends on a specific date, or a schedule that ends after a certain number of backups are created.
    9. Automatically delete backup—The backup retention policy. This is enabled by default with a 14-day retention period. You can select the date the backup expires or the number of days, weeks, or months the backup is retained, or disable the option and permanently retain the backup.
  5. Click Create.
