AO_100301: Merge Layers requires the same geometry type for all inputs
The two selected layers do not have the same geometry type.
There are three possible geometry types for a layer: points, lines, and polygons. The two selected layers must have the same geometry type.
Solution
To resolve the error, do one of the following:
  • Select input layers that have the same geometry as each other.
  • Use Find Centroids to create point features from lines or polygons.
  • Use Create Buffer to create polygons from points or lines.
