Complex function
License:
Available when the organization is configured for raster analytics.
The Complex function computes the amplitude or phase values given a complex raster layer. It can also compute amplitude, phase, or complex values given a real and imaginary data type as the raster input.
Notes
This function is typically used with synthetic aperture radar (SAR) imagery that has a complex data type, or both real and imaginary data types.
A complex data type is used to describe complex numbers, a number system that allows for a solution to the square root of negative number. A complex number can be described as a pair of two numbers, a real value and an imaginary value. An imaginary value can be described as a number in the form b*i, where b is a nonzero real number and i = . The term imaginary is used because there is no real number that has a square root of negative value.
If complex values must be converted to amplitude or phase values, only the Raster input is required.
If real and imaginary values must be converted to amplitude, phase, or complex values, both Raster and Imaginary Raster inputs are required.
This function can be used in a mosaic dataset.
Parameters
Parameter
Raster
The input raster layer.
Imaginary Raster
The imaginary raster input.
Value Type
Specifies which value type to calculate:
  • Amplitude—Produces an output containing the amplitude values. This is the default.
  • Phase—Produces an output containing the phase values.
  • Complex—Produces an output containing the complex values.
