Convert Feature to Raster
The Convert Feature to Raster tool converts features to a raster.
The output is a hosted imagery layer.
Usage notes
Convert Feature to Raster includes configurations for input features, analysis settings, and the result layer.
Input features
The Input features group includes the Input feature layer parameter, which identifies the features to be converted to raster. This tool uses the cell center to determine the value of a raster pixel. For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer, except features that have been removed using a filter. Environment settings, such as Processing extent, are not reflected in the feature count.
Analysis settings
The Analysis settings group includes the following parameters:
Value field is used to assign values to the output raster. It determines the type of output raster. If the field is integer, the output raster will be integer; if it is floating point, the output will be floating point.
Output cell size is the cell size of the output raster.
Result layer
The Result layer group includes the following parameters:
Output raster name is the name of the output raster layer that will be created and added to the map or scene.
The name must be unique. If a layer with the same name already exists in your organization, the tool will fail and you will be prompted to use a different name.
Save in folder specifies the name of a folder in My content where the result will be saved.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
The default processing extent for raster analysis tools and raster functions is Display extent. This default is different from other types of analysis.
Outputs
This tool produces one output raster of the rasterized features.
Usage requirements
This tool requires the following user type and configurations:
Creator, Professional, or Professional Plus user type
Publisher or Administrator role, or an equivalent custom role
Available when the organization is configured for raster analytics with a premium capability license
Resources
Use the following resources to learn more:
Convert Feature to Raster in ArcGIS REST API
convert_feature_to_raster in ArcGIS API for Python
Convert Feature To Raster in ArcGIS Enterprise
Feature to Raster in ArcGIS Pro
