Is Null function
License:
Available when the organization is configured for raster analytics.
Determines which values from the input raster are NoData on a pixel-by-pixel basis.
Returns a value of 1 if the input value is NoData and a value of 0 for pixels that are not NoData.
Notes
This function can be used with the Con function to change NoData pixels to a value.
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The input raster being tested to identify the cells that are NoData (null). The input can be either integer or floating-point type. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
