Lookup function
License:
Available when the organization is configured for raster analytics.
Creates a new raster by looking up values found in another field in the table of the input raster.
Notes
Only numeric (integer or floating point) field type is supported. If the field is integer, the output will be an integer raster; otherwise, the output raster will be a floating-point raster.
Parameters
Parameters |
Description |
Raster |
The input raster that contains a field from which to create a new raster. It can be either integer or floating-point type. |
Field |
Field containing the desired values for the new raster. It has to be a numeric type. |
