Rasterize Features function
License:
Available when the organization is configured for raster analytics.
The Rasterize Features function converts a polygon, polyline, or point feature class layer to a raster layer.
Notes
Keep the following in mind when using the Rasterize Features function:
Features are assigned pixel values based on a field in the feature's attribute table.
Options are provided to resolve overlapping features.
The output of this function does not have a raster attribute table (RAT).
Parameters
Parameter |
Description |
Raster |
Select a raster in the Contents pane to use to define the cell size and extent for the feature conversion. |
Input Features |
Field |
Provide the feature class field to use to assign pixel values for each feature. If no field is provided, pixel values will be assigned based on the feature class object ID. This parameter only supports numeric field types. |
Resolve Overlap Method |
Specify how features that overlap will be managed:
