Summarize Categorical Raster
License:
Available when the organization is configured for raster analytics.
The Summarize Categorical Raster tool generates a table containing the pixel count for each category in each slice of an input multidimensional categorical raster.
The output is a table.
Examples
Calculate the number of pixels in each land cover class for a multidimensional raster containing 30 years of land cover data.
Usage Notes
Summarize Categorical Raster includes configurations for the input layer, summary areas, and the result table.
Input Layer
The Input layer group includes the following parameters:
Input categorical raster specifies the categorical raster to be summarized. The input raster must be of integer type.
If a raster attribute table exists, the tool will use the unique values in the table to compute pixel count. If a raster attribute table does not exist, the tool will scan pixels to find unique values. If the input raster has a raster attribute table with a
Class_NameorClassNamefield, the output table will use the names listed in that field. Otherwise, the output will use class values from theClass_ValueorClassValuefield. Field names are not case sensitive.Dimension specifies the dimension used to summarize the input raster. If there is more than one dimension and no value is specified, all slices will be summarized using all combinations of dimension values.
Summary Areas
The Summary areas group includes the following parameters:
Area of interest specifies the polygon feature layer containing the area or areas of interest to use when calculating the pixel count per category. If no area of interest is specified, the entire raster dataset is used.
Field specifies the field in the polygon feature layer that defines each area of interest.
Result Layer
The Result layer group includes the following parameters:
Output summary table is the name of the output table. The name must be unique. If a table with the same name already exists in your organization, the tool will fail and you will be prompted to use a different name.
Save in folder specifies the name of a folder in My content where the result will be saved.
Environments
This tool honors the following analysis environments:
The default processing extent for raster analysis tools and raster functions is Display extent, which differs from other types of analysis.
Outputs
The output is a table that contains the pixel count for each category.
Usage requirements
This tool requires the following user type and configurations:
Creator, Professional, or Professional Plus user type
Publisher or Administrator role, or an equivalent custom role
Available when the organization is configured for raster analytics with a premium capability license
Resources
Summarize Categorical Raster in ArcGIS REST API
summarize_categorical_raster in ArcGIS API for Python
Summarize Categorical Raster in ArcGIS Pro
