Example: End-to-end deep learning workflow
Deep learning models are typically large and require significant computational power. By integrating the training of models with ArcGIS API for Python, you can create deep learning models that are both compact and suitable for mobile deployment.
In this example notebook workflow, the Multi-task Road Extractor model is used to extract a road network from satellite imagery.
Requirements
To perform this workflow, you must meet the following requirements:
  • Download the training dataset, comprising SpaceNet data for road centerlines in the Paris region.
    If you cannot access the training dataset, Raster Server is required to generate suitable training data in the required format.
  • To run this workflow, the maximum memory limit of the notebook environment must be set to 15 GB. The memory limit in Standard and Advanced notebook environments are set to 4 GB and 6 GB respectively by default. To change this limit, sign in to ArcGIS Enterprise Manager and click Capabilities > Settings (Notebook services) > Runtimes.
    The memory limit necessary for this workflow depends on the size of the training data.
Python library imports
Import the following Python libraries:
from arcgis.gis import GIS
gis = GIS("home")
import os, zipfile
from pathlib import Path
from arcgis.learn import prepare_data, MultiTaskRoadExtractor
Upload data to the workspace
Upload the dataset into the notebook workspace under Files as a .zip file containing labeled images chips in a folder named images.
#Adding zipped file from workspace
filepath = training_data = gis1.content.get('itemID')
filepath = training_data.download(save_path='/arcgis/home/input', file_name=training_data.name)
filepath
assert os.path.exists(filepath) == 1
#Extract zip
with zipfile.ZipFile(filepath, 'r') as zip_ref:
    zip_ref.extractall(Path(filepath).parent)
#Get the data path
output_path = Path(os.path.join(os.path.splitext(filepath)[0]))
Prepare your data
The prepare_data() function in ArcGIS API for Python prepares data for deep learning workflows. The function reads training samples and automates the data preparation process by applying various transformations and augmentations to the training data. These augmentations allow for models to be trained with limited data and prevent overfitting of models.
data = prepare_data(
    path=output_path,
    batch_size=4,
    chip_size=512
data.classes
For information on the prepare_data() function parameters, see the arcgis.learn API reference.
Visualize the data
Once you have prepared the data, you can use the show_batch() function to visualize samples from it.
data.show_batch(alpha=1)
Load the model architecture
The Multi-task Road Extractor framework in arcgis.learn supports two architectures that can be set using the parameter mt1_model. The parameter can be set to either the linknet or hourglass architecture.
Model specific advanced parameters can optionally be set at this stage:
  • gaussian_thresh—Sets the Gaussian threshold, which allows you to set the required road width.
  • orient_bin_size—Sets the bin size for orientation angles.
  • orient_theta—Sets the width of the orientation mask.
model = MultiTaskRoadExtractor(data, mtl_model="hourglass")
Calculate the learning rate
ArcGIS API for Python uses fast.ai's learning rate finder to find an optimal learning rate for training the models. Use the lr_find() method to find an optimal learning rate to train a robust model. Once you have determined the learning rate with the first run of the model, you can pass it as a fixed value for further runs while retraining the model.
lr = model.lr_find()
#lr =  0.0005754 #from the first run
Model fitting
The fit() method is used to train the model. The method requires an input for the epoch parameter. An epoch defines the number of times the model will be exposed to the entire training dataset. Each epoch allows the model to learn and adjust its weights based on the data. In the following example, the model is run for three epochs for testing purposes.
It is recommended that you start with 25 epochs to obtain a more accurate model for deployment.
model.fit(3, lr=lr, early_stopping=True)
Visualize the results
To validate the results of the model in the notebook, you can use the show_results() method to compare the model's predictions with random ground truth images.
model.show_results(rows=4, thresh=0.2)
Save the model
Once you have confirmed the accuracy of the trained model, save it for future deployment. By default, the model will be saved as a .dlpk file to the models subfolder within the training data folder.
model.save('/arcgis/home/road_model_for_spacenet_data')
Deploy the model
The saved .dlpk file can now be deployed with other datasets and shared within your organization. For information on how to consume a .dlpk file, see Example: Inferencing using a pretrained model.
