Measure area in a scene
In Scene tools
, use the Measure area tool
to calculate areas in the scene. Horizontal laser lines are projected on the terrain and objects in the scene. This shows the vertical height of the pointer in the scene as you measure. It is helpful to see the heights of objects relative to other objects and the terrain.
Use the Measure area tool
to calculate the area of a polygon you draw. The Measure area tool labels the area and the total length of the perimeter. These values also appear in the panel.
Area—Area of the polygon
Perimeter—Perimeter length of the polygon
To measure area, do the following:
Click Scene tools
to access the measure tools.Click Measure area
.Click in the scene to start adding points to the polygon.
Double-click to close the path and calculate the polygon area. Alternatively, click the starting point again to close the path.
The area may be visualized and calculated in one of the following ways:
If all vertices align onto a single plane (either horizontal or sloped), the area is calculated relative to this plane.
If the vertices have varying z-values and they create a nonplanar surface, the visualization and the measurements show the area that is projected to a horizontal plane.
Click New Measurement to start a new measurement.
Tip:
Press the Ctrl key to temporarily disable snapping to the orange visual cues. Release the Ctrl key to enable snapping again.
When the polygon perimeter is greater than 100 kilometers, the measurement visualization is simplified.
Adjust measurements
To adjust the measurement, hover over a point and drag. As you drag points, Scene Viewer displays the adjusted values in the scene and panel. You can change the unit of measure under Unit.
In local scenes that are in projected coordinate systems (with exception of Web Mercator), the measurements are displayed as Euclidean values.
In scenes that are in geographic coordinate systems and in Web Mercator, the measurements are displayed as geodesic values. The exception is when using the area measurement tool and the perimeter is less than 100 kilometers, in which case the measurements are displayed as Euclidean values.
Depending on the scene's projected coordinate system, the values may not be accurate.
