Manage content in the user workspace
In the notebook editor, you can work with content in your ArcGIS Notebooks workspace to add files to your notebook or download them to your machine. Click the Files button to open the Files pane. You can also work with files by going to the Notebooks tab, clicking the Manage button, and clicking Workspace files.
Browse content in the workspace
The Files pane provides a browser for the files in your workspace. The default folder is home. The Manage workspace files page provides a browser for all your files in the home folder where you can create folders, upload files, and delete and rename content.
Upload content to the workspace
To work with content and resources from your machine, you must first upload the file to your notebook's workspace through the notebook editor or on the Manage workspace files page. Once the files are uploaded, you can reference their file path in an open notebook and any other notebooks you own with filepath = /arcgis/home/folder/filename.
Upload files using the notebook editor
To upload files using the notebook editor, complete the following steps:
  1. In the Files pane, browse to the /arcgis/home folder.
    /arcgis/home is the workspace directory and is different from the home/arcgis root directory.
  2. Optionally, click New folder to create a folder in the /arcgis/home workspace where you will upload content.
  3. Click Choose file to upload, and browse to the file.
  4. Select the file.
    The file is uploaded to the workspace.
Upload files on the Manage files page
To upload files on the Manage workspace files page, complete the following steps:
  1. On the Notebooks tab, click the Manage button, and click Workspace files.
  2. Click Upload files .
  3. Drag the files from your machine to the New Items window, or click Your device to select files on your machine.
    The files are uploaded to the workspace.
Files that are uploaded to the notebook workspace are not stored as items in your organization and are not deleted when the notebook is deleted. To delete files, select the file in the Files pane, and click Delete. Optionally, select the file on the Manage workspace files page, and click Delete. If you are removed from your organization, all content in your notebook workspace is permanently deleted.
Download content from the workspace
You can save a file from the workspace to your local machine. In the notebook editor Files pane, browse to the file and select it. The file is automatically downloaded to your machine. Optionally, find the file on the Manage workspace files page, click the More Options button , and click Download. The file is downloaded to your machine.
Transfer files in a notebook workspace
To change ownership of a member's workspace, which transfers all content in the workspace to another member in your organization, complete the following steps:
  1. Sign in with the default administrator role or with a role that has both Portal settings — Servers and Portal settings — Security and infrastructure privileges.
  2. Go to the Notebooks tab, click Manage, and click Manage files.
  3. Click inside the member dialog box.
  4. Use the search as needed to find the member's workspace.
    If you do not see a username listed, the member does not have a notebook workspace.
  5. Select the member, provide their workspace name, review their files, and click the Transfer workspace button.
  6. Select the member to whom you want to transfer the workspace, and provide a folder name.
    Transferred items are all stored in a single folder.
  7. Click Transfer content.
    The member's workspace is transferred to the new owner that you specified.
Set up a scratch workspace environment for use with ArcPy
The scratch workspace is intended for output data that you do not plan to maintain.
To create and use a scratch workspace environment, complete the following steps:
  1. Use the code below to create a scratch file geodatabase in the user workspace directory, if it does not already exist, and set the scratch geodatabase as the scratch workspace.
    import arcpy
    if not arcpy.Exists('/arcgis/home/scratch.gdb'):
        arcpy.management.CreateFileGDB('/arcgis/home','scratch.gdb')
    arcpy.env.scratchWorkspace = '/arcgis/home/scratch.gdb'
  2. Use the code below to verify that the geodatabase is set as the scratch geodatabase environment.
    print(arcpy.env.scratchGDB)
Create a folder to use as a scratch workspace
To create a folder to use as a scratch workspace, complete the following steps:
  1. Use the code below to create a folder in the user workspace, if one does not already exist, and set that folder as the user workspace.
    import arcpy
    if not arcpy.Exists('/arcgis/home/scratch'):
        arcpy.management.CreateFolder('/arcgis/home', 'scratch')
    arcpy.env.scratchWorkspace = '/arcgis/home/scratch'
  2. Use the code below to verify that the folder is set as the scratch folder environment.
    print(arcpy.env.scratchFolder)
