Use Windows Active Directory and client certificate authentication to secure access
When using Windows Active Directory to authenticate users, you can use public key infrastructure (PKI)-based client certificate authentication to secure access to your organization.
To use Integrated Windows Authentication and client certificate authentication, you must use ArcGIS Web Adaptor (IIS) deployed to Microsoft's IIS web server. You cannot use ArcGIS Web Adaptor (Java Platform) to perform Integrated Windows Authentication. If you haven't done so already, install and configure ArcGIS Web Adaptor (IIS) with your organization.
Configure your portal with Windows Active Directory
First, configure the portal to use SSL for all communication. Then update your portal's identity store to use Windows Active Directory users and groups.
Configure the organization to use HTTPS for all communication
Complete the following steps to configure the organization to use HTTPS:
Sign in to the organization website as an administrator.
The URL is in the format
https://organization.example.com/<context>/home.Click Organization and click the Settings tab, and then click Security on the left side of the page.
Enable Allow access to the portal through HTTPS only.
Configure your identity store using Active Directory users and groups
Next, update your organization's identity store to use Windows Active Directory users and groups.
Sign in to ArcGIS Enterprise Manager as an administrator of your organization.
https://site.example.com/<site context>/manager.Click Security > Identity Store.
The option buttons under User store and Group store allow you to select how the users and groups will be managed for your organization.
Select Windows under the User store.
With Windows users, you can use the built-in group store or a Windows group store. The text boxes in the User store and group store configuration section will change depending on the type of group store selected.
In the User store and group store configuration, enter the appropriate information in each text box.
The descriptions of each text box are as follows:
Username (Required)
Password (Required)
Are usernames case sensitive?—Yes or No
User first name attribute (Required)—The directory server attribute for a user's first name
User last name attribute (Required—The directory server attribute for a user's last name
User email attribute (Required)—The directory server attribute for a user's email address
Domain controller (Required)
Domain controller mapping
Click Save when you are finished entering the information for configuring your identity store.
Add organization-specific accounts
By default, organization-specific users can access the ArcGIS Enterprise organization. However, they can only view items that have been shared with everyone in the organization. This is because the organization-specific accounts have not been added and granted access privileges.
Add accounts to your organization using one of the following methods:
Individually or in bulk (one at a time, in bulk from a
.csvfile, or from existing Active Directory groups)
It's recommended that you designate at least one organization-specific account as an administrator of your portal. You can do this by choosing the Administrator role when adding the account. When you have an alternate portal administrator account, you can assign the initial administrator account to the User role or delete the account. See About the initial administrator account for more information.
Once the accounts have been added and you complete the steps below, users can sign in to the organization and access content.
Install and enable Active Directory Client Certificate Mapping Authentication
Active Directory Client Certificate Mapping is not available in the default installation of IIS. You must install and enable the feature.
Install Active Directory Client Certificate Mapping Authentication
Complete the following steps to install Client Certificate Mapping on Windows Server 2016, 2019, 2022, and 2025:
Open Server Manager.
In the Server Manager Dashboard, click Add roles and features.
The Add Roles and Features Wizard appears.
Accept the default settings and click Next on the Before You Begin, Installation Type, and Server Selection pages.
On the Server Roles page, enable Web Server (IIS).
On the dialog box that appears, click Add Features and click Next.
On the Features and Web Server Role (IIS) pages, click Next.
On the Role Services page, expand the Security section, select Client Certificate Mapping Authentication, and click Next.
On the Confirmation page, click Install.
When the installation completes, click Close to close the wizard.
Enable Active Directory Client Certificate Mapping Authentication
After you install Active Directory Client Certificate Mapping, complete the following steps to enable the feature:
Start Internet Information Server (IIS) Manager.
In the Connections node, click the name of your web server.
Double-click Authentication in the Features View window.
Verify that Active Directory Client Certificate Authentication is displayed.
If the feature is not displayed or unavailable, you may need to restart your web server to complete the installation of the Active Directory Client Certificate Authentication feature.
Double-click Active Directory Client Certificate Authentication and choose Enable in the Actions window.
A message appears indicating that SSL must be enabled to use Active Directory Client Certificate Authentication. You'll address this in the next section.
Configure ArcGIS Web Adaptor to require SSL and client certificates
Complete the following steps to configure ArcGIS Web Adaptor to require SSL and client certificates:
Start Internet Information Services (IIS) Manager.
Expand the Connections node and select your ArcGIS Web Adaptor site.
Disable all forms of authentication.
Select your ArcGIS Web Adaptor from the Connections list again.
Double-click SSL Settings.
Enable the Require SSL option, and choose the Require option under Client certificates.
Click Apply to save your changes.
For client certificate authentication to work on Microsoft Windows Server 2022, TLS 1.3 must be disabled under the HTTPS site bindings.
Verify you can access the portal using Windows Active Directory and client certificate authentication
Complete the following steps to verify you can access the portal using Windows Active Directory and client certificate authentication:
Open the portal.
https://organization.example.com/<context>/home.Verify that you are prompted for your security credentials and can access the website.
Prevent users from creating their own built-in accounts
If you enabled users to create their own built-in portal accounts before configuring IWA, they will still be able to do so after you've configured it. For more information on how to control the creation of new accounts, see Allow users to add their own accounts.
