ArcGIS Server web services
An ArcGIS Server web service represents a GIS resource—such as a map or feature class—that is located on an ArcGIS Server site and is made available to client apps such as Map Viewer.
You can add ArcGIS Server web services to your ArcGIS Enterprise organization to use them in apps throughout ArcGIS. How you add a service depends on how you need to use it.
  • To create a reference to an ArcGIS Server web service to make it easier for others to access and discover the service, do one of the following:
  • You can also add an ArcGIS Server web service directly to Map Viewer or Scene Viewer, and configure the service layer within a specific map or scene. You can use the maps and scenes you save with those layer configurations in apps.
Creating items that reference services
To help people discover and use your ArcGIS Server web services in their apps, add them as items to My content in your organization or publish web services to a federated server. You can store settings and information on the items, configure the item style and pop-ups, and use these items in maps, apps, and scenes.
When you share the configured items, it allows other people to take advantage of the settings you made and allows them to use the items in their own maps, apps, and scenes.
The following tables show the types of items created for each type of ArcGIS Server web service you add. Note that not all ArcGIS Server web services are supported as items.
When you add the services listed in the following table, ArcGIS Enterprise creates layer items that allow you to visualize the data. Store configuration settings with the item layers, such as styles and pop-ups, making these settings available to anyone who can access the layer.
Layer item
Feature service (map service with feature access enabled)
Feature layer
If you publish the feature service from a nonspatial table, the item is a table layer.
A single layer in a feature service
Feature layer
Map service (cached or dynamic)
Map image layer
Map service (tiles only)
Tile layer (raster)
A single layer in a map service
Feature layer
Feature layers created from a layer in a map service are read-only; you cannot enable editing on them.
The services listed in the following table create items you or the administrator can use as tools in ArcGIS Enterprise.
Item type
Geocode service
Locator
GeoEnrichment service
GeoEnrichment Service
Geometry service
Geometry Service
Adding services directly to maps and scenes
You can add web services to Map Viewer and Scene Viewer directly using the REST endpoint URL of the service.
When you add ArcGIS Server web services to a map or scene using the service URL, you configure settings for the web service layer in the map or scene. Those settings are stored in and are specific to that individual map or scene. You can add the following to a map or scene using the service URL:
  • Feature service (map service with feature access enabled)
  • Map service, cached or dynamic
  • OGC services
  • A layer from a map service or feature service
Tip:
If you need to change the URL for an ArcGIS Server web service after it has been saved in a map, you can do that from the Settings tab of the web map's item page.
Secure services
When you add a secure ArcGIS Server service as an item to an ArcGIS Enterprise organization, you choose whether to store the credentials necessary to access the service with the layer item. The option to store credentials is available only if your administrator has added the ArcGIS Server to the list of allowed proxy hosts. Only built-in ArcGIS Enterprise or built-in ArcGIS Server credentials can be stored with a service. If credentials are not stored, you may be prompted to enter them when you access the service. If the credentials are stored with the layer item, you won't be prompted for them. To change credentials after adding the item, you can edit the item details and provide a different username or password. Storing credentials with the item is only supported for token-based services.
You cannot alter the source URL for items that store credentials to access a secure service.
It is recommended that you make all services accessible using HTTPS only, which encrypts the information in the service when it is transmitted over the internet. If you own or have privileges to administer secure services with embedded credentials and your secure service's data source is using the HTTP protocol, replace http with https in the URL on the Settings tab of the service item's item page.
Usernames may be case sensitive depending on how your identity systems are managed.
When you store your credentials for a secure service, the layer item behaves like a proxy, in that all requests to the service go through ArcGIS Enterprise. This proxy adds some delay when accessing the service and is slower than going directly to the service. Slow responses from the proxied server may result in timeouts.
When you use secure services, you may want to limit use of these items by limiting the URL or IP addresses that can access them.
Limit usage
You may want to limit usage to control how many times and by whom a secure service is accessed, especially if the service and the map you use it in are shared with the public. To do this, specify a rate limit and designate the specific referrer URLs or IPs that can access the secure service. See Limit usage of secure services for instructions.
