Comma-separated values files
You can use data stored in a comma-separated values (CSV) text file (.csv) in ArcGIS Enterprise. The following list summarizes how you can use these files and provides links to instructions. The sections after the functionality list provide information on proper formatting and tips for using .csv files in ArcGIS Enterprise.
  • Add files as items and share them so others can download the data.
  • Add a file containing latitude and longitude coordinates from a local or network drive to Map Viewer. This uses the location information in the file to draw features on the map and stores the information in the map as a layer. Once the file is added to the map, you can edit the properties of the layer that is created. For example, you can configure pop-ups, change symbols, set the visibility range, enable editing, and remove pop-ups.
  • Add a file that doesn't contain location information to a map as a table. This is useful when you want to join nonspatial data—for example, property damage claims related to a recent tornado—to spatial data such as a ZIP codes layer using the Join Features analysis tool.
  • If the file is stored on a publicly accessible website, you can reference it from the map in Map Viewer as a layer on the web. If the .csv file contains coordinate information, updates made to the file on the web will appear in the map. If the .csv file contains address or place information, updates made to the file on the web will not be reflected in the map.
  • If you have privileges to publish hosted feature layers, you can publish the data in .csv files and share the hosted layer so others can use it.
.csv files store information in plain text. The first row in the file defines the names for all subsequent fields. Fields can be separated with a comma, semicolon, or tab. Other separators are not supported.
As no data types are enforced in the file, ArcGIS Enterprise relies on the field names and specific formatting in the fields to interpret the data type that should be applied.
The following sections contain information about supported data formats in .csv files and what you need to consider when adding the files to a map.
Location fields
To use .csv files in your organization, the file must include location fields. Location fields can contain coordinate, address, or place information. The first row in the file must contain the location field names. Addresses can be stored in one or more fields. Coordinates must be in two separate fields.
If the file contains coordinate fields, ArcGIS Enterprise uses these fields to locate the features on the map. ArcGIS Enterprise supports the following coordinate types:
  • Longitude and latitude*
  • Latitude and longitude*
  • Military Grid Reference System (MGRS)
  • United States National Grid (USNG)
*Latitude and longitude information must be in decimal degrees.
The following location fields are supported:
  • Latitude, Longitude
  • Lat, Long
  • Longitude83, Latitude83
  • Longdecdeg, Latdecdeg
  • Long_dd, Latdd
  • Lng
  • Y, X
  • Ycenter, Xcenter
  • Xcenter, Ycenter
  • Point-y, Point-x
  • Point-x, Point-y
  • MGRS
  • USNG
  • Address
  • City
  • State
  • ZIP
Date and time fields
Date and time fields in .csv files are assumed to contain Universal Time Coordinated (UTC) date and time and stored as such. That's because the physical location of the server hosting the data can be anywhere in the world. The alternative of storing date and time in a local time zone leads to problems, especially if you, or the server hosting the data, move to another time zone.
Whenever the value of a date or time field is displayed, it is converted from UTC time into your local time. This is done by querying your computer for its time zone setting. For example, suppose your computer is set to Pacific standard time (PST). PST is eight hours behind UTC, so when UTC time is 10:00 a.m., it is 2:00 a.m. PST.
When you publish a hosted feature layer from a .csv file, you can specify the time zone of the data. The specified time zone is used to mitigate the offset because ArcGIS Enterprise assumes date and time data to be in UTC. For example, when a .csv file containing date fields is published with Pacific standard time selected as the time zone, all date and time values in your .csv file will have eight hours added as part of the conversion to UTC.
If the date fields in the .csv file contain a date but not a time value, a time value of midnight is assigned when you publish a hosted feature layer. Therefore, if you don't specify a time zone when you publish, the data will be stored with a time value of midnight (UTC). When you view the data, time will be converted to the local time, potentially changing the date. For example, 7/28/2009 0:00 is midnight (UTC) on July 28, 2009. If you view the data from a computer in the Pacific standard time zone, the date and time will be displayed as 7/27/2009 16:00. Specifying the time zone when you publish eliminates this offset when viewed in the time zone specified.
The first table below lists date and time formats that will result in a date field in the hosted feature layer that you publish from a .csv file. The second table lists formats that result in other date and time fields in the hosted feature layer that you publish from a .csv file. Values in a format not in these lists will be created as string data types in the resulting hosted feature layer, or, if only numerals are present, as an integer.
Format
Example
M/DD/YYYY
7/28/2009
MM/DD/YYYY
07/28/2009
M/DD/YY
7/28/09
MM/DD/YY
07/28/09
YYYY/MM/DD
2009/07/28
YYYY/MM/DD hh:mm:ss
2009/07/28 17:23:00
YYYY/M/DD hh:mm:ss
2009/7/28 17:23:00
YYYY-MM-DD hh:mm:ss
2009-07-28 17:23:00
YYYY-M-DD hh:mm:ss
2009-7-28 17:23:00
Format
Resultant field type
Example
YYYY-MM-DD
Date only
2009-07-28
DD/MM/YYYY
Date only
28/07/2009
hh:mm:ss
Time only
17:23:00
hh:mm:ss.sss
Time only
17:23:00.025
Considerations for publishing date and time fields
Keep the following in mind when publishing date fields:
  • When you specify a time zone when you publish a .csv file, the selected time zone is applied to all date and time values that exist in the .csv file at the time you publish or when overwriting the feature layer.
  • To apply a time zone only to individual records, you can specify an offset from UTC for the respective record. For example, if you had a date value of Tuesday, July 28, 2009 5:23 AM+8:00, that reflects a time zone that is eight hours ahead of UTC. See www.worldtimezone.com for a list of the world's time zones. When the time zone is specified per record in the .csv file, a time zone selected during publishing is applied to those records that do not have an offset specified.
  • If you alter date fields in the feature layer you published, including if you alter the hosted feature layer to use the Keep track of who created and last updated features option, the date fields capture values in the editor's local time and convert to UTC with the time offset applied.
  • When you export data from a hosted feature layer for which you specified a time zone when you published, no offset is applied. Data is exported in UTC format, which effectively maintains the time zone you selected when publishing.
  • Only standard time zones are available in the Time Zone list when publishing. However, daylight saving time is automatically applied if a date value in your .csv file falls within daylight saving time and the selected time zone recognizes daylight saving time.
Considerations for adding files to a map
  • The more address fields you include, the more accurate the geocoding results will be. For example, address and ZIP code will yield better results than just address.
  • The address field can contain multiple parts of an address (sometimes called single-line geocoding).
  • When you add a file to Map Viewer, you can define field types.
  • If the file contains more spaces than separators in the field names (the first line of the file), you may have trouble adding the file as a layer in a map. Remove extra spaces in the field names and try adding the file again.
  • Order and case do not matter (for example, you could have 519 East 86 Street,New York,NY,10028 or 519 east 86 street,new york,ny,10028). However, every row in the file must follow the same order.
  • When you add a file with coordinate information or addresses while signed in, 4,000 rows can be added directly to the map. Files with more than 4,000 rows must be published as a hosted feature layer.
  • When you add a file with addresses as an anonymous user or when you are not signed in, 250 features can be added directly to the map. Files with more addresses than this must be published as a hosted feature layer.
  • If the data in the file contains non-English characters—for example, characters specific to the French, Russian, Greek, Japanese, or Arabic alphabets—the file you import must be encoded as Unicode or UTF-8, and not ASCII. If you import an ASCII-encoded file containing non-English characters, it may display attribute values using unexpected characters. You can save a text file as UTF-8 or Unicode in Microsoft Windows. Open the file in a text editor such as Notepad, click File > Save As, and choose UTF-8 or Unicode from the Encoding drop-down menu shown at the bottom of the Save As dialog box.
  • If you use a URL to add a .csv file that includes number fields with decimals, the decimal characters in the file should match the format that your system language supports. For example, if your system is set to English, the file should use periods as decimals. If your system is set to French, the file should use commas as decimals.
  • When a .csv file containing latitude and longitude information is added to a map, the latitude, longitude coordinates are converted to the spatial reference of the current basemap.
  • .csv file items (including those with address information) cannot be added to a map; only the source file on disk or a hosted feature layer published from the .csv file can be added to a map.
