Enable layers for offline mapping
You can enable offline viewing and editing of feature layers in your organization. To take feature data offline from ArcGIS Enterprise, you must enable sync on the feature layer and add the sync-enabled feature layer (or layers) to a map that is enabled for offline use.
How you enable sync on a feature layer depends on whether you are using a hosted feature layer or an ArcGIS Server feature layer (feature service).
Enable a hosted feature layer for offline mapping
If you enable offline editing (sync) from ArcGIS Pro when you publish a hosted feature layer to your portal, the data is automatically configured to allow synchronization to occur. If you publish a hosted feature layer from a file in your portal, enable sync from the Settings tab of the hosted feature layer's item page. See Manage hosted feature layer editing for instructions.
Enable an ArcGIS Server feature layer for offline mapping
Before you can enable an ArcGIS Server feature layer for offline mapping, you must prepare the source data. See Prepare data for use in offline feature services in the ArcGIS Pro help for details.
Next steps
Once you enable sync on the feature layers you need to take offline, add the layers to a map and enable the map for offline use.
