Hosted layers
You can publish your maps and data as hosted layers to the organization. Web, desktop, and mobile apps can access hosted layers through the internet if you allow it.
Hosted layers allow you to share maps, scenes, features, 3D data, and imagery with other members of your organization.
Prerequisites to publish hosted layers
You must have privileges to create, update, and delete content and publish hosted layers. If the option to publish is not available, check with your organization administrator to confirm that you're a member of a role that has been assigned the correct privileges to publish hosted layers.
Types of hosted layers
You can publish the following types of hosted layers.
Feature layers
Hosted feature layers support vector feature querying, visualization, and editing. Hosted feature layers are most appropriate for visualizing data on top of your basemaps. In web apps, hosted feature layers are drawn by the browser and support interactive highlighting, queries, and pop-ups.
See Publish hosted feature layers for more information.
Once you publish a hosted feature layer, you can create views of the data in the feature layer. Hosted feature layer views reference the same data as the hosted feature layer used to create the view, but you can apply different editing, sharing, and other settings to the view. See Create hosted feature layer views for more information.
Feature layer views
If you have publishing privileges and need a different view of your hosted feature layer beyond changing its style and presentation—for example, you want to apply different editing capabilities or share the data with different groups—you can create a hosted feature layer view from your hosted feature layer. A hosted feature layer view is similar to a copy of a layer but allows you to control more than how the layer is displayed. For example, you can create a hosted feature layer view when you need to support different editing capabilities for different groups of users. Many organizations need to share data with the entire organization and simultaneously allow members in a specific group keep that data up to date. Hosted feature layer views provide a direct way to do this. When you publish your hosted feature layer, you can share it with a group or groups whose members need to edit the layer. Then, for the rest of the organization, you can create a hosted feature layer view that references the original hosted feature layer but with editing disabled. Because the two layers share the same data, as group members edit the original hosted feature layer, the rest of the organization sees those changes immediately.
WFS layers
Hosted WFS layers are read-only views of hosted feature layers. WFS layers follow the Open Geospatial Consortium (OGC) WFS specification. A hosted WFS layer and the hosted feature layer from which you publish it share the same data and initial metadata.
See Publish hosted WFS layers for more information.
Tile layers
Hosted tile layers support fast map visualization using a collection of predrawn map images, or tiles. These tiles are created and stored on the server after you upload your data.
See Tile layers for a description of each type of tile layer and how to publish it.
Scene layers
Hosted scene layers support fast map visualization of 3D data using a collection of cached tiles. Caches are generated from 3D data stored in scene layer packages that you generate from ArcGIS Pro.
See Publish 3D layers for more information.
Imagery layers
Hosted imagery layers are image services that are hosted in your organization. They support a large number of raster types and image products so you can create, share, and analyze your remote sensing imagery and raster data.
See Publish hosted imagery layers for more information.
Hosted layer dependencies
Hosted layers have dependencies on the items from which you create them. For example, if you publish a hosted feature layer from a shapefile you uploaded, deleting the shapefile will prevent you from performing such operations as overwriting the hosted feature layer.
Similarly, if you publish other hosted layers from a hosted feature layer, you create a dependency between the layers. You can publish all of the following from a primary hosted feature layer:
Hosted tile layer
Hosted WFS layer
Hosted map image layer (Can only be published from ArcGIS Pro)
These dependent hosted layers have a relationship with the hosted feature layer from which you create them.
Hosted WFS and feature layer views reference the data in the hosted feature layer used to publish them; therefore, they are entirely dependent on the hosted feature layer for access to the data.
Hosted tile layers are dependent on the hosted feature layer for certain functionality such as pop-ups.
Dependent layers and their primary hosted feature layer must have the same owner. Organization administrators must reassign ownership of the primary hosted feature layer first. When the administrator does that, ownership of all dependent layers (and the file used to generate the primary hosted feature layer) will be owned by the same organization member.
You must delete all dependent layers before you can delete the hosted feature layer from which you created them.
These dependencies extend to layers you publish from hosted feature layer views. The hosted layers you publish from a hosted feature layer view are related to both the view and the hosted feature layer from which the view was created. You must delete the dependent layers before you can delete the hosted feature layer view.
Hosted feature layer views have an additional restriction; you cannot set a definition on a hosted feature layer view if it has a dependent hosted tile layer.
The Created from value under Details on the hosted layer's item page tells you which layer or file was used to publish the hosted layer. The Published as and Other Views values indicate which other hosted layers have been published or views created from the hosted feature layer.
Clients that can use hosted layers
Hosted layers communicate through the well-known GeoServices REST Specification and can consequently be used by Esri and third-party apps. You can view hosted layers in Map Viewer, and you can also make your own app using ArcGIS Maps SDKs, ArcGIS Instant Apps, or ArcGIS Experience Builder. Other supported client apps include ArcGIS Field Maps and ArcGIS Pro. See ArcGIS apps and ArcGIS Enterprise on Kubernetes for additional clients.
Access to hosted layers
By default, hosted layers are private when published and are only accessible to the user who published them. Hosted layers do not appear in search results and aren't part of any group by default. You can make hosted layers available to specific groups in your ArcGIS Enterprise organization, to all members of your organization, or to anyone who can connect to your organization. See Share items for more information.
